I am using Peridynamics Lammps to run the simulation for a nanoindentation; however, when I tried the pair style of eps, it tells me a segmentation fault in the code. This didn’t happen when I try the other pair styles like lps, pmb, and ves.
My input file is like this:
units si
boundary p s p
atom_style peri
atom_modify map array
neighbor 0.0010 bin
lattice sc 0.0005
Create desired sample
region sample cylinder y 0.0 0.0 0.020 -0.020 0.0 units box
a segmentation fault in the code. This didn't happen when I try the other
*and I got a fault message like this:*
LAMMPS (4 Jun 2014)
Lattice spacing in x,y,z = 0.0005 0.0005 0.0005
Created orthogonal box = (-0.02 -0.02 -0.02) to (0.02 0 0.02)
Created 205943 atoms
Setting atom values ...
205943 settings made for density
205943 settings made for volume
25115 atoms in group lower
180828 atoms in group mobile
25115 settings made for type
5023 atoms in group upper
3280 atoms in group middle
Setting up run ...
Peridynamic bonds:
total # of bonds = 23774850
bonds/atom = 115.444
Memory usage per processor = 645.669 Mbytes
Step Temp E_pair E_mol TotEng Press Volume
0 0.17560964 0 0 7.4897661e-19
1.5600559e-14 3.20064e-05
Segmentation fault (core dumped)
Is there a know bug in this EPS mode?
no. just what i would call sloppy programming. if you run the code under a
debugger, you'll see that there is a large stack allocation been done which
will lead to a segfault on all setups that do have by default a limited
stack.
please find attached a patch that replaces the stack allocation with a
proper heap allocation.
this also optimizes the process of clearing and copying the temporary
array through calling memset()/memcpy().
which results in a significant speedup on my test machine (about 20%)
