I’ve been trying to run a simulation involving random introduction of Li atoms in my simulation box to observe how the system reacts
I’m using LAMMPS version 23 Jun 2022, with the ReaxFF force field, on a linux machine. Parallelisation with OpenMPI v 4.1.4.
I have observed that trying to insert Lithium atoms in the simulation box after the type has been allocated and the force field is set up - leads to a segmentation fault.
However this behaviour is not observed if I insert a token lithium atom anywhere in the sim box after type allocation and before force field set up.
The error is only reflected on the run screen, and not in the log file.
Here is my input script:
#init
units real
atom_style charge
read_data EC_electrolyte.data extra/atom/types 1
pair_style reaxff ../lmp_control
mass 19 6.94
#create_atoms 19 random 1 654785 NULL overlap 2.5
pair_coeff * * ../ffield.reax.COHNSLi C C C C C C H H H H H H O O O O O O Li
region ranLi block EDGE 10 EDGE EDGE EDGE EDGE
#minimisation
fix mynve all nve/limit 0.1
fix chg all qeq/reaxff 1 0 8.0 1.0e-3 reaxff
dump mdmp all custom 100 VC_electrolyte.lammpstrj id type xu yu zu
minimize 1.0e-2 1.0-2 100000 100000
unfix mynve
fix mynvt all nvt temp 1 500 100
fix LiInsert all deposit 15 19 100 654894 region ranLi id next near 1.5 attempt 50
thermo 100
timestep 0.10
run 5000
I have stored the on screen error message in the following text document. Please also find attached, the other relevant files
SegmentationFault.txt (3.8 KB)
EC_electrolyte.data (292.3 KB)
ffield_Islam (36.0 KB)
lmp_control (1009 Bytes)
