Segmentation Fault using qeq/point
Hello all,
I currently am looking into incorporating charge transfer while using an 2NN MEAM potential.
I aimed to use the qeq/point fix to take care of the charge transfer while using the hybrid/overlay command to combined meam and coul/long (for electrostatics).
I wanted to run some test runs to make sure I fully understand how to use these commands, however whenever I set up a run I instantly run into a segmentation fault error.
My pair style commands look like:
pair_style hybrid/overlay meam coul/long 4.8
pair_coeff * * meam /home/vella/Potentials/libraryLi_H_D_v2.meam Li2NN D /home/vella/Potentials/Li_H_v2.meam Li2NN D
pair_coeff * * coul/long
kspace_style pppm 1.0e-4
where the second pair_coeff command provides the path to the relevant meam files
My fix commands look like:
fix 1 all npt temp 50.0 50.0 0.13 iso 0.0 0.0 1.07
fix 2 all qeq/point 10 4.8 1.0e-6 200 param1.qeq
Where my param1.qeq has the following parameters (taken from the Rappe and Goddard paper (1 is Li and 2 is H))
1 3.006 9.544
2 4.5280 27.7807
I don’t know if there is something I’m obviously doing wrong based on these commands but any insight into the source of the segmentation fault would be appreciated.
Thank you,
Joseph Vella
Can you post the complete, but simple, input deck?
Ray
