Hello lammps users, I have placed the following code inside another loop. When I execute the program I
get the error (mentioned below). This piece of code works before the loop starts and gives the correct result.
However when placed inside another loop this gives the error of exit code:11
Can you please suggest what could be the problem ?
Code:
label loopdelete
variable i loop ${N_0}
variable x equal type[$i]
if “$x==15” then &
“print $x”
next i
jump in.mysys loopdelete
Error:
BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 11
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
