Segmentation fault with hybrid ellipsoid peri molecular
Dear Experts,
I try to run LAMMPS (version 23Jun2022) using: atom_style hybrid ellipsoid peri molecular for a toy system. The data file is:
LAMMPS data file for hybrid ellipsoid + peri + molecular
2 atoms
2 atom types
1 ellipsoids
0.0 10.0 xlo xhi
0.0 10.0 ylo yhi
0.0 10.0 zlo zhi
Masses
1 1.0
2 1.0
ID type x y z ellipsoidflag density volume molID
Atoms
1 1 1.0 1.0 1.0 1 1.0 1.0 1
2 1 2.0 2.0 2.0 0 1.0 1.0 2
Ellipsoids
1 1.0 1.0 1.0 1.0 0.0 0.0 0.0
And the lammps input file is:
units lj
read_data data.hybrid_example
pair_style zero 10.0
pair_coeff * *
neighbor 0.3 bin
fix 1 all nve/asphere
thermo 1
run 10
However, I always get error:
mpirun -np 2 lmp -in in.hybrid
LAMMPS (23 Jun 2022 - Update 4)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
WARNING: Atom style hybrid defines both, per-type and per-atom masses; both must be set, but only per-atom masses will be used (src/atom_vec_hybrid.cpp:133)
WARNING: Per-atom field rmass is used in multiple sub-styles; must be used consistently (src/atom_vec_hybrid.cpp:167)
Reading data file …
orthogonal box = (0 0 0) to (10 10 10)
[seurat:271768] *** Process received signal ***
[seurat:271768] Signal: Segmentation fault (11)
[seurat:271768] Signal code: Address not mapped (1)
[seurat:271768] Failing at address: (nil)
1 by 1 by 2 MPI processor grid
reading atoms …
[seurat:271768] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x45330)[0x76ba4ac45330]
If I use a single atom_style, either ellipsoid, or peri or molecular then it works fine. Also, the hybrid ellipsoid molecular works fine. The problem occurs if I include the style peri.
Thank you very much for any hints.
Please read the guidelines and revise your post, your inputs are difficult to read. Also, note that:
are not specific to LAMMPS and therefore not very helpful here.
This is what a LAMMPS error message looks like (obtained using version 29Aug2024):
ERROR on proc 0: Fix nve/asphere requires extended particles (…/fix_nve_asphere.cpp:54)
which clearly states what the problem is.
Simon
You may want to use a more recent version also.
Thanks you so much. It works with the version 2024.
Lesson: before complaining about a crash, always check with the latest version.
Thanks. In fact this hybrid worked well with the version 2017, but surprisingly doesn’t work with the version 2022, but then work again with 2024.
