Hello all,
I tried to look for a place to send information about bugs found within
LAMMPS' website but I did not find. Is there such a place for that?
I have found LAMMPS segfoult when I write:
variable prod_cycles equal 100
fix temp_field_fix flow_g ave/chunk 10 \(v\_prod\_cycles/10\)
{prod_cycles}binning_cmp temp file temp_profile.dat
I tracked down the problem to be "\{prod\_cycles\}binning\_cmp" so this
line has to be "{prod_cycles} binning_cmp" (with a space in between).
So it seems to be a case not handled when the parameters of this fix are
parsed. Although the syntax is wrong a segfoult is not desirable.
The output (printed to screen) is attached. I am using the May2015
version with opt, user-misc, kspace and molecule packages compiled. I do
not include the log because due to the crash it gives no relevant
information. If you need the input files I can give them to you (there
are a few).
I just wanted to help, so tell me if you need more info.
Regards,
Eduardo
output.txt (12.8 KB)
Hello all,
instructions for reporting (potential) bugs are given in the manual
(as one should expect).
Thanks to point me to the right page. Apparently I did it the right way!
Regards,
Eduardo
not entirely.
there are many ways how somebody can screw up with variables and you
don't provide a minimal input deck to reproduce it.
chances are, that the "bug" is somewhere else in your input, and this
line in your output is a very strong hint to confirm it:
ERROR: Invalid thermo keyword in variable formula (../variable.cpp:1716)
Well, if I separate the parameter names (as the command expect) the
simulation runs fine. So it is likely that there is no problem
elsewhere. It is just a undesired case not taken into account while
checking parameters I guess. , when I have a bit of time I will make a
simple test case so if that makes things easier for you.
Regards,
Eduardo
When I add these 3 lines (without the space) to bench/in.lj
compute binning_cmp all chunk/atom bin/1d x lower 1.0
fix temp_field_fix all ave/chunk 10 (v_prod_cycles/10) &
I get this error:
ERROR: Expected integer parameter in input script or data file (…/fix_ave_chunk.cpp:51)
When I add the space, it runs fine.
This is with the current 6 Jul 2015 version.
