ethanol.index (291 Bytes)
ethanol.mol (423 Bytes)
ethanol.parm (547 Bytes)
npt_3000_0.7.log (34.2 KB)
npt_3000_0.7.txt (847 Bytes)
water_ethanol_box_3000_0.7.data (1.9 MB)
Dear LAMMPS users,
I am performing NPT simulations of ethanol-water mixtures using the TIP4P model for water and the OPLS-UA model for ethanol. The total number of molecules is fixed at 3000, and I varied the ethanol mole fraction across five values: 0.05, 0.10, 0.15, 0.20, and 0.70.
For mole fractions up to 0.20, the final density obtained after equilibration agreed well with experimental values (within 1–2% error). However, for the highest ethanol mole fraction of 0.70, the simulated density was 0.75 g/cm³, which is significantly lower than the experimental value of ~0.85 g/cm³.
The following files are attached:
[ethanol.index|attachment](upload://8eCnjOBgJFikGNDdyiV4W6UYpNK.index) (291 Bytes) [ethanol.mol|attachment](upload://8sTHMbfmZS8XryWsIMwbcT443r8.mol) (423 Bytes) [ethanol.parm|attachment](upload://iyiIZh1VFtgJDkiuSuSLideWDs7.parm) (547 Bytes) [npt_3000_0.7.log|attachment](upload://wiAT4lVSO1xyTcGZ3YtE5891JeD.log) (34.2 KB) [npt_3000_0.7.txt|attachment](upload://ojylSu2BIqcz1I1OIzDPWMNIpGR.txt) (847 Bytes) [water_ethanol_box_3000_0.7.data|attachment](upload://2TyCqd0ORjDhAcDn0Jsa9BJAVYQ.data) (1.9 MB)water_ethanol_box_3000_0.7.data– Structure file for 3000 molecules at 70% ethanolnpt_3000_0.7.txt– LAMMPS input script for NPT equilibration at 315 K, 1 atmnpt_3000_0.7.log– Log file showing temperature, pressure, and density over timeethanol.mol– Ethanol molecule templateethanol.parm– Parameter file for ethanol (pair, bond, angle, dihedral definitions)
Why does the density decreases?
Thank you very much in advance for your support.
asas
