When I was performing nvt simulations of a pure water system between graphene electrodes, the water used a rigid SPC/E model.
I used de-constrained bond angles for the water molecules. However, I found that lammps shake could not accurately identify the bonds angles for constraining (this is reflected in the log file). This caused my water molecules to deform so drastically that the two hydrogen atoms were almost next to each other. In my data file, atoms 1-12 are graphene electrodes, and atoms 13 and 14 are O and H of water molecules, for a total of 2823 water molecules.
data:
LAMMPS data file via write_data, version 22 Dec 2022, timestep = 0
12501 atoms
14 atom types
5646 bonds
1 bond types
2823 angles
1 angle types
0 29.473 xlo xhi
0 29.778 ylo yhi
0 270 zlo zhi
Masses
1 12.011
2 12.011
3 12.011
4 12.011
5 12.011
6 12.011
7 12.011
8 12.011
9 12.011
10 12.011
11 12.011
12 12.011
13 15.9994
14 1.008
in:
fix shake all shake 0.0001 20 0 a 1 b 1
log:
Finding SHAKE clusters …
0 = # of size 2 clusters
2823 = # of size 3 clusters
0 = # of size 4 clusters
0 = # of frozen angles
find clusters CPU = 0.001 second
Actually, it should be 2823 angles, not key length, and frozen angles is 0.
I confirm that my force field parameters are fine. I also tested the versions lammps-23Jun2022, lammps-29Sep2021, lammps-8Feb2023, all with the same error.
Here, I attach my in and data files and the output log file.
run_nvt.zip (364.8 KB)
Any help will be appreciated!
Thanks!
