I need your help in using LAMMPS for bonded networks.
I am trying to reproduce the paper: Link.
I have generated a network with only bonded interactions. As per the paper, I want to apply a simple shear to the network and then do the second part of the simulation. So, when I applied a simple shear using change_box command and minimized it with the cg method, I ended up with a state with almost zero stress. I found the value of stress ~ 10^(-15).
LAMMPS version: LAMMPS (2 Aug 2023 - Update 3)
The input script:
#Set up basic simulation stuff
dimension 2
units lj
atom_style molecular
atom_modify id yes map hash sort 1 2.0
comm_modify vel yes cutoff 2.0
neighbor 4.0 bin
read_data initconf-Z4.1.d
mass * 1
timestep 0.001
#Variables
variable L0 equal $(lx)
variable delta equal 0.05*${L0}
variable shear equal xy/${L0}
variable sigma equal -pxy
velocity all create 0.0 2349851
reset_timestep 0
#Interaction parameters
pair_style zero 4.0
pair_coeff * *
bond_style harmonic/restrain
bond_coeff 1 1
run 0
#Compute initial state
dump initdc all custom 1 dump-Min-Init.lammpstrj id mol type x y vx vy fx fy
dump_modify initdc format line '%d %d %d %0.16g %0.16g %0.16g %0.16g %0.16g %0.16g'
run 0
undump initdc
print "# step temp v_shear v_sigma" file Thermo.dat screen no
#Deform system [Simple shear]
change_box all triclinic
change_box all xy delta ${delta} remap boundary pp pp pp units box
compute gpres all pressure NULL bond virial # global pressure tensor (virial part)
run 0
dump dc all custom 1 dump-Min.lammpstrj id mol type x y vx vy fx fy
thermo_style custom step temp v_shear v_sigma pxx pyy pxy fmax
thermo_modify press gpres
thermo 1
fix 1 all enforce2d
fix 2 all viscous 1
fix 3 all nve
min_style cg
min_modify dmax 1e-2 line forcezero #backtrack
minimize 1.0e-25 1.0e-12 100000000 100000000
print "$(step) $(temp) $(v_shear) $(v_sigma)" append Thermo.dat screen no
undump dc
uncompute gpres
unfix 1
unfix 2
unfix 3
2024-04-05T23:00:00Z
