Shearing microgels
Hello everyone,
I am trying to shear my microgel and I would like to calculate its gyration tensor components along the way as well as the intrinsic viscosity and I can’t seem to get it to work:
LAMMPS script for polymer gel under shear flow
Box and units (LJ units and periodic boundaries)
units lj
atom_style bond
Neighbor list settings
neighbor 0.3 bin
neigh_modify every 1 delay 1 check yes
RESTART file generation
restart 100000 mgel.restart.a mgel.restart.b
READ initial configuration
read_data data_final_alfa0
reset_timestep 0
Convert box to triclinic for shear deformation
change_box all triclinic
Define groups
group all type 1
Dump configurations
dump mgelconf all custom 50000 mgel.dump.* id type x y z vx vy vz ix iy iz
dump_modify mgelconf format line “%d d .10f .10f .10f .10f .10f %.10f %d %d %d”
dump_modify mgelconf pbc yes
dump_modify mgelconf sort id
Pair interactions
pair_style lj/cut 1.122462048309
pair_modify shift yes
pair_coeff * * 1.0 1.0
Bond interactions (FENE)
bond_style fene
special_bonds fene
bond_coeff 1 30 1.5 1 1
Shear flow setup using SLLOD algorithm
Shear rate = 0.001 in LJ units
variable shear_rate equal 0.001
Fixes for SLLOD integration
First: deform the box at constant shear rate
fix deform all deform 1 xy erate ${shear_rate} remap v
Second: Use SLLOD equations with NVT thermostat
The “temp” thermostat acts on thermal velocities relative to shear flow
fix sllod all nvt/sllod temp 1.0 1.0 0.2 tchain 30
Compute for stress tensor components
compute stress all stress/atom NULL virial
compute p all pressure NULL temp c_stress
compute p all pressure temp c_stress
Compute gyration tensor and related properties
compute gyrtensor all gyration tensor
compute rg all gyration
Extract individual components of gyration tensor
variable Rg2 equal c_rg
variable Rgxx equal c_gyrtensor[1]
variable Rgyy equal c_gyrtensor[2]
variable Rgzz equal c_gyrtensor[3]
variable Rgxy equal c_gyrtensor[4]
Compute intrinsic viscosity
σ_xy = -1/V * ∑(R_ix * F_iy)
Intrinsic viscosity = σ_xy / (shear_rate)
variable box_vol equal vol
variable sigma_xy equal -(c_p[4]) # c_p[4] is the xy component of stress tensor
variable intrinsic_viscosity equal v_sigma_xy/${shear_rate}
Additional computes for monitoring
compute ke all ke
compute pe all pe
compute temp_all all temp
Density profile calculation
compute densprof all chunk/atom bin/sphere 0 0 0 0.0 120.0 120
fix fordensprof all ave/chunk 2 20 10000 densprof density/number file densprofmgel
Recentering fix
fix recentermgel all recenter 0 0 0 shift all units box
Thermodynamic output with enhanced observables
thermo 1000
thermo_style custom step temp etotal pe ke press c_rg v_Rgxx v_Rgyy v_Rgzz v_Rgxy v_sigma_xy v_intrinsic_viscosity
Timestep
timestep 0.002
Minimization
minimize 1.0e-4 1.0e-6 1000 1000
Production run
run 50000000
Write final configuration
write_data data_final_sheared
I am happy for any feedback, thank you in advance!!
Leah
PS.: I also later on would like to shear a bulk of tighly packed microgels, do I simply remove the recentering command and lammps takes proper care of it (Lees-Edwards-boundary conditions, …) or is it not possible this way. Right now with one microgel I can recenter it and no boundaries are in the way but I am aware that this is not the case in bulk simulations.
Please have a good luck at this post and follow the suggestions: Please Read This First: Guidelines and Suggestions for posting LAMMPS questions
Otherwise you are not likely to get much help since we won’t be able to understand what your problem is and reproduce it to make suggestions.
Thank you for the fast reply, I apologise for I was too inconcrete…
I got the problems with the variables solved and now the code is running.. I shear like this:
#which now runs but I also hopes will produce useful results
#AND then write output the quantities I am interested like so
Sum the xy components over all atoms
compute p all reduce sum c_stress[4]
Convert to macroscopic stress
variable sigma_xy equal -c_p/(vol)
#variable sigma_xy equal -(c_p[4]) # c_p[4] is the xy component of stress tensor
compute ke all ke
compute pe all pe
Recentering fix
thermo 1000
thermo_style custom step temp etotal pe ke press v_sigma_xy v_intrinsic_viscosity
… (any feedback appreciated)
Now it also would be cool if you could tell me: If I move to a bigger system (here I have one microgel kept CENTERED in a very large box with no contact to any boundaries) with many microgels tightly packed, is lammps then able to account for the needed boundary conditions? And would I be therefore getting physical simulations and also data without any kinks after stopping and restarting using the restart file.
Leah
My previous statement still applies.
