I wish to do some shock simulation to calculate Hugoniot points and as well as EOS. From literature and lammps discussion archive I am bit used to with NEMD type shock simulation i.e. “momentum mirror” method. But as my current interest is to use reactive forcefield like reax/c to describe water as our target system, then realizing the computational cost I am trying to use MSST method with reax/c for water. Regarding this I have some questions, although Qs are not really directly related to lammps issues yet please allow me.
I’m getting the values of TD state variables which represent the Hugoniot curve of water properly but from rdf analyses I’m not getting the freezing of water to iceVII which have confirmed by the past literature by using this reax and NEMD. Here my confusion is that is there any restriction of MSST that it cannot produce the structural reconstruction and/or phase transition properly or this is due to any wrong in my simulation ? I have gone through the documents of MSST but have not seen this type of restriction.
By MSST as I understand that, it can achieve the steady state of the sample assuming that a shock with specified shock velocity have passed through it. So can it be true to say that it can achieve the final state as gained by NEMD simulation ?
But in case of my simulation, from NEMD it is well known that after passing the shock front it reaches a equilibrium state and after that the P and T decreases accordingly when the shock front moves further i.e. when the front travels a considerable distance. But after a msst “ns” simulation when it is showing that the sample is beyond 100nm then also T and P is not decreasing, rather keeps the equilibrium value at per Us. Can anybody make some comment to clear.
Thanks for your help and comment.
Liu.
