Can someone please answer Lili’s question. I also can not figure it out.
Regards,
Mojib
Hi All,
May I ask a question following this thread regarding the meaning of the
"args" of keywords "*pos*" and "*vel*" in "fix wall/piston command?" The
doc says that
*"pos* args = z
z = z coordinate at which the piston begins (distance units)
*vel* args = vz
vz = final velocity of the piston (velocity units)"
which seems: pos needs only one argument z, and vel needs only one
argument vz (the z component of the piston).
But in the Example part of the doc: fix walls all wall/piston zlo pos
1.0 0.0 0.0 vel 0.0 0.0 10.0 units box
There are three args for each, what is the meaning of them?
Thank you very much,
Lili
