Hi all –
See the subject header. Based on my understanding, I would expect yes, but here is what I find in the following comparison:
a) Run 200 steps of a vanilla simulation vs.
b) Run 100 steps of a vanilla simulation, write a restart file, clear, read restart file and run another 100 steps
c) Run 100 steps of vanilla simulation, then run another 100 steps
Up through the first 100 steps, a) and b) are exactly the same. Upon restart in case (b) however, I find
…………… less important details….
97 1.4245376 1.1271994 0.29733823 1.1342887 6.1267096 0.059720584 -0.22840436
98 1.4263275 1.1396418 0.28668572 1.1468093 6.2627651 0.060336261 -0.14811741
99 1.4248708 1.1473828 0.27748806 1.154599 6.7280443 0.060951937 0.17075202
100 1.4239158 1.1533493 0.27056654 1.1606031 6.6992116 0.061567613 0.21413923
Loop time of 0.00396991 on 1 procs for 100 steps with 160 atoms
System init for write_restart …
Reading restart file …
restart file = 4 Apr 2014, LAMMPS = 4 Apr 2014
triclinic box = (0 0 -0.769595) to (15.3919 12.3135 0.769595) with tilt (0.0615676 0 0)
160 atoms
Resetting global state of Fix 1 Style nvt/sllod from restart file info
Setting up run …
Memory usage per processor = 1.17087 Mbytes
Step TotEng KinEng PotEng Temp Press Xy Pxy
100 1.4240155 1.1533493 0.2706662 1.1606031 6.6999316 0.061567613 0.21370038
101 1.4216912 1.1573916 0.26429956 1.1646708 6.8546852 0.062183289 0.22302251
102 1.4196133 1.1572581 0.26235521 1.1645365 6.6490058 0.062798965 0.18065531
Upon restart, inspection of step 100 reveals that the potential energy is slightly different, although the kinetic energy
is exact to the resolution of the output.
In case ©, similar inconsistency is observed when the run starts up again, although this time minor differences in both the kinetic and potential energy are observed:
Loop time of 0.00631189 on 1 procs for 100 steps with 160 atoms
Setting up run …
Memory usage per processor = 1.52854 Mbytes
100 1.4239747 1.1533085 0.2706662 1.160562 6.6998972 0.061567613 0.21267989
101 1.4216505 1.157351 0.26429956 1.1646299 6.8546508 0.062183289 0.22200269
102 1.4195728 1.1572176 0.26235521 1.1644957 6.6489716 0.062798965 0.17963617
Can anyone confirm whether this behavior has a rational explanation?
Input scripts reproduced below, happy to supply input/output files if requested. Also, note these cases were run in the 4Apr14 version of lammps.
Thanks in advance,
Peter
Here is the input scripts for case (a)
