I am planning to simulate interaction between a methyl radical (CH3) and a carbon surface to "see" what happens (sticking, reflexion...).
I am using REBO potential to model interaction between C and H atoms.
I have two questions concerning the modelling of interactions between atoms of the CH3 radical (and actually also of the carbone substrate) using LAMMPS.
First I was wondering if I should use the bond_style command or not. Is the pair_style command not sufficient for modelling interaction between atoms ?
Second, what would be the difference whether the bond_style command is set or not ?
Laurent.
using LAMMPS.
atoms ?
no. in LAMMPS bond order potentials like REBO compute bond
contributions on the fly as part of the non-bonded calculations.
set or not ?
if you use a bond style, you would define *additional* and
*fixed* bonded interactions. this will automatically lead to
pairs being removed from the neighbor list due to the default
special_bonds settings and thus completely mess up the
bond order potential (unless you set special_bonds to lj/cut 1.0 1.0 1.0)
any other special bonds setting will lead to inconsistent
results for the bond order potential.
let us know if you have any additional questions about this.
