I can replicate the simulation crash at the same density, and why it is happening is a combination of: maybe an over-aggressive timestep (0.001 tau for a dense LJ system with constrained bonds? hmm), and definitely issues minimizing the system with rigid bonds.
During minimization, LAMMPS emulates SHAKE with stiff harmonic bonds – the LJ default is 1e6. This is much larger than the bond strength (100) you were applying. This is not perfect – for it to work, the average bond force (at the applied bond strength) must be much larger than the average total of other forces, and in such a dense system, even one overlap will exert enough force to distort these bonds.
With some quick testing I can see that even at a bond strength of 1e4, the minimization leaves some bonds very far from their constrained length, as seen in this log portion (I’ve attached the input file below):
WARNING: Using fix shake with minimization.
Substituting constraints with harmonic restraint forces using kbond=1e+04 (src/RIGID/fix_shake.cpp:386)
Neighbor list info ...
update: every = 1 steps, delay = 0 steps, check = yes
master list distance cutoff = 2.122
ghost atom cutoff = 4.5
binsize = 1.061, bins = 142 142 1
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair lj/cut, perpetual
attributes: half, newton on
pair build: half/bin/newton
stencil: half/bin/2d
bin: standard
Setting up cg style minimization ...
Unit style : lj
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 6.173 | 6.173 | 6.173 Mbytes
Step Temp c_bondmin c_bondave c_bondmax PotEng KinEng TotEng Press
0 0.013335263 1 1 1 6.1225404e+16 0.0099956597 6.1225404e+16 3.7616888e+16
10 0.013335263 0.97012697 1.0001073 1.0430835 1.8963e+09 0.0099956597 1.8963e+09 1.1650882e+09
20 0.013335263 0.84456084 0.99966527 1.207643 1852.7709 0.0099956597 1852.7809 1143.3355
30 0.013335263 0.83253455 1.0045644 1.5232982 21.112777 0.0099956597 21.122772 4.2179434
34 0.013335263 0.93753248 1.0035426 1.3783311 6185.6341 0.0099956597 6185.6441 -318.29048
Loop time of 0.0081456 on 4 procs for 34 steps with 2304 atoms
When the dynamics starts, SHAKE must “recover” those bonds, and in a dense system it will likely create new clashes when doing so.
Note that how big a clash will crash the simulation is related to the timestep used – even from the above minimisation, a timestep of 1e-4 (instead of 1e-3) allows for recovery:
0 0.013335263 1 1 1 7.1055745 0.0099956597 7.1155702 1.8088773
500 99.707991 0.999998 1 1.0000018 16.830112 74.737718 91.56783 4.1339008
1000 43.060012 0.99999821 0.99999999 1.0000017 7.2184397 32.27632 39.494759 1.4855276
1500 18.807721 0.99999806 1 1.0000017 4.7923341 14.097628 18.889962 0.76162338
2000 6.7990798 0.99999838 1 1.000002 5.4331775 5.0963589 10.529536 0.24861886
2500 2.6820699 0.99999822 0.99999998 1.0000016 5.0294338 2.0103883 7.0398221 0.076629885
3000 1.2987469 0.99999805 1 1.0000016 4.492729 0.97349645 5.4662254 -0.0063997328
3500 0.63516738 0.99999809 1 1.0000017 4.2535215 0.47609985 4.7296214 -0.017895961
4000 0.42629755 0.9999984 1 1.0000016 4.04293 0.31953813 4.3624681 -0.016010793
4500 0.23383998 0.9999981 0.99999997 1.0000017 3.9925577 0.17527849 4.1678362 0.061431975
5000 0.13920116 0.99999822 0.99999998 1.0000015 3.9576093 0.10434045 4.0619498 0.07905399
5500 0.063306893 0.99999819 1 1.0000017 3.9552278 0.047452692 4.0026805 -0.0077798396
6000 0.043964427 0.99999832 0.99999999 1.0000019 3.9334785 0.032954239 3.9664327 0.0956323
6500 0.027975573 0.99999826 0.99999998 1.0000017 3.9245569 0.020969538 3.9455264 0.042068665
7000 0.021080426 0.99999808 1 1.0000017 3.9169237 0.01580117 3.9327249 0.0034243914
7500 0.016066038 0.9999985 1 1.0000018 3.9133556 0.012042556 3.9253981 -0.077301464
8000 0.014225456 0.99999824 0.99999999 1.0000018 3.9102627 0.010662918 3.9209256 0.021958655
Loop time of 0.622448 on 4 procs for 8000 steps with 2304 atoms
The integrator and equations of motion correctly transfer the high potential energy of the clash into kinetic energy, and the Langevin thermostat successfully dissipates it within 0.8 tau (compatible with the thermostat’s time constant of 0.1 tau). Also note how the eventual equilibrium pressure is not that high – it’s in isolated initial clashes that you are encountering this issue.
Input file:
# presets
dimension 2
units lj
atom_style bond
# build box
variable scale equal 3 # okay at 1
region simbox block 0 $(v_scale*50.0) 0 $(v_scale*50.0) -0.01 0.01
create_box 2 simbox bond/types 1 extra/bond/per/atom 1
mass * 1.0
molecule dumbbell mymol.txt
create_atoms 1 random $(v_scale*v_scale*128) 9362 simbox mol dumbbell 8751
velocity all create 0.01 235092 mom yes rot yes dist gaussian
# potentials
neighbor 1.0 bin
bond_style harmonic
bond_coeff 1 100.0 1.0
pair_style lj/cut 1.122
pair_modify shift yes
pair_coeff 1 1 1.0 1.0 1.122
pair_coeff 2 2 1.0 1.0 1.122
pair_coeff 1 2 1.0 1.0 1.122
comm_modify vel yes cutoff 4.5
# thermo and computes
thermo 10
compute bondlen all bond/local dist
compute bondmin all reduce min c_bondlen inputs local
compute bondave all reduce ave c_bondlen inputs local
compute bondmax all reduce max c_bondlen inputs local
thermo_style custom step temp c_bondmin c_bondave c_bondmax pe ke etotal press
# fix shake -- only STARTS to give stable results for kbond >= 1e8 if timestep = 1e-3
fix rigid all shake 0.0001 20 0 b 1 kbond 100
# minimize and run
minimize 1e-4 1e-6 10000 100000
reset_timestep 0
fix integrate all nve
fix noise all langevin 0.01 0.01 0.1 543621
fix two_dim all enforce2d
thermo 500
timestep 1e-3
# does not crash for kbond 1e4 + timestep 1e-4 -- "enough time" to resolve clashes
run 8000
