Dear all
Good day.
I run few simulations for pristine graphene and polycrystalline. Recently I face problem in LAMMPS simulations in the cluster for the polycrystalline. When I run the jobs in cluster few simulation jobs from my all simulations stop automatically in between with the following error.
mpirun noticed that process rank 3 with PID 0 on node cph-cXX exited on signal 11 (Segmentation fault).
A part of the input file:
------------------------ INITIALIZATION ----------------------------
atom_style atomic
-------------------- ATOM DEFINITION 10/17/13----------------------------
read_data coord_PCG.data
mass 1 12.0107
---------------------- FORCE FIELDS 9/23/13------------------------------
pair_style airebo 1.92 1 1
pair_coeff * * CH.airebo C
#################################### GROUP DEFINE #####################################
###################################### Computes ##########################################
some compute command
############################### Defining stress and strain variables ################################
some variable command
###################################### Thermo commands ####################################
thermo 1000
thermo_style custom step temp lx ly lz pxx pyy pzz time pe etotal v_Up1 v_Up2 v_Up3 v_Down1 v_Down2 v_Down3 v_p2 v_p3 v_p4 v_p5 v_p6 v_p7 v_p8 v_L1 v_L2 v_L3 v_R1 v_R2 v_R3
thermo_modify line one format float %20.10f
timestep 0.001
dump myDump all custom 10000 dump.lammpstrj id type x y z c_STRESS[1] c_STRESS[2] c_STRESS[3] c_STRESS[4] c_STRESS[5] c_STRESS[6]
dump_modify myDump append yes first yes
####################################### Minimization #########################################
min_style cg
fix 1 all box/relax iso 0.0 vmax 0.001
minimize 1e-25 1e-15 50000 10000
unfix 1
reset_timestep 0
####################################### DEFORMATION ##################################
fix lower Down setforce NULL 0.0 0.0 #freezing lower boundary atoms
fix upper Up setforce NULL 0.0 0.0 #Setting zero forces only in x and z directions
fix left2 left setforce 0.0 NULL 0.0 #freezing lower boundary atoms
fix right2 right setforce 0.0 NULL 0.0 #Setting zero forces only in x and z directions
############ Equilibrating the system ##############
velocity group2 create 500 9284155
fix 1 group2 nve
fix 2 group2 temp/berendsen 500 500 0.1
run 40000
unfix 1
unfix 2
velocity group2 create 300 9284155
fix 1 group2 nve
fix 2 group2 temp/berendsen 300 300 0.1
run 30000
unfix 1
unfix 2
fix 3 group2 npt temp 300 300 0.1 iso 1.0 1.0 1.0 #Tdamp is 100 times the timestep
run 100000
unfix 3
