Dear LAMMPS users,
I am using 29 September 2021 version of LAMMPS. I have looked the similar errors discussed in this mailing list. However, my problem seems different. The errors are shown below.
[n37] *** Process received signal ***
[n37] Signal: Segmentation fault (11)
[n37] Signal code: Address not mapped (1)
[n37] Failing at address: 0x149c66f57008
[n37] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12730)[0x149c68846730]
[n37] [ 1] /usr/lib/x86_64-linux-gnu/pmix/lib/pmix/mca_gds_ds21.so(+0x2936)[0x149c66f5a936]
[n37] [ 2] /lib/x86_64-linux-gnu/libmca_common_dstore.so.1(pmix_common_dstor_init+0x9d3)[0x149c66f4d733]
[n37] [ 3] /usr/lib/x86_64-linux-gnu/pmix/lib/pmix/mca_gds_ds21.so(+0x25b4)[0x149c66f5a5b4]
[n37] [ 4] /lib/x86_64-linux-gnu/libpmix.so.2(pmix_gds_base_select+0x12e)[0x149c670ac46e]
[n37] [ 5] /lib/x86_64-linux-gnu/libpmix.so.2(pmix_rte_init+0x8cd)[0x149c6706488d]
[n37] [ 6] /lib/x86_64-linux-gnu/libpmix.so.2(PMIx_Init+0xdc)[0x149c67020d7c]
[n37] [ 7] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_pmix_ext2x.so(ext2x_client_init+0xc4)[0x149c670f8fe4]
[n37] [ 8] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_ess_pmi.so(+0x2656)[0x149c677c5656]
[n37] [ 9] /lib/x86_64-linux-gnu/libopen-rte.so.40(orte_init+0x29a)[0x149c678c711a]
[n37] [10] /lib/x86_64-linux-gnu/libmpi.so.40(ompi_mpi_init+0x252)[0x149c68301e62]
[n37] [11] /lib/x86_64-linux-gnu/libmpi.so.40(MPI_Init+0x6e)[0x149c6833017e]
[n37] [12] *****/lammps/bin/lmp_alisha[0x410913]
[n37] [13] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb)[0x149c67fea09b]
[n37] [14] *****/lammps/bin/lmp_alisha[0x41082a]
[n37] *** End of error message ***
The problem is that some times the simulations are running fine with the same input script, whereas, some times giving this error and exiting.
Thank you in advance.
