Simulation Crashes Randomly with 'Non-numeric Pressure' ERROR
Hello everyone,
I hope you’re doing well. I’m encountering a problem where my simulation randomly stops with the following error:
ERROR: Non-numeric pressure
Interestingly, I’m able to continue the simulation using the last restart file, and I’ve checked—there’s no atom overlap issue. The error occurs unpredictably: sometimes after 1 ns, sometimes earlier or later.
I came across this related topic:
I initially used a null coefficient line, but even after omitting it, the error persists.
I’m using LAMMPS version: 29 Aug 2024 - Update 1.
Here is my ff after modification :slight_smile:
pair_style hybrid/overlay lj/cut 12.0 coul/long 12.0
pair_modify tail yes
# pair_coeff * * lj/cut 0.0 0.0
pair_coeff 2 4 lj/cut 5.95E-04 3.2607
pair_coeff 2 3 lj/cut 5.60E-04 3.2696
pair_coeff 2 6 lj/cut 5.95E-04 3.2607
pair_coeff 2 5 lj/cut 5.30E-04 3.2338
pair_coeff 4 4 lj/cut 6.18E-02 3.4478
pair_coeff 3 4 lj/cut 4.54E-02 3.626
pair_coeff 4 6 lj/cut 6.18E-02 3.4478
pair_coeff 1 4 lj/cut 7.06E-04 5.4523
pair_coeff 4 9 lj/cut 1.04E-03 4.4456
pair_coeff 4 5 lj/cut 8.72E-01 2.8954
pair_coeff 3 3 lj/cut 1.24E+00 2.7351
pair_coeff 3 6 lj/cut 4.54E-02 3.626
pair_coeff 1 3 lj/cut 8.69E-04 4.3654
pair_coeff 3 9 lj/cut 1.46E-03 4.3654
pair_coeff 3 5 lj/cut 5.26E-03 4.2407
pair_coeff 6 6 lj/cut 6.18E-02 3.4478
pair_coeff 1 6 lj/cut 8.69E-04 4.3654
pair_coeff 6 9 lj/cut 1.04E-03 4.4456
pair_coeff 5 6 lj/cut 8.72E-01 2.8954
pair_coeff 1 5 lj/cut 8.76E-04 4.3654
pair_coeff 5 9 lj/cut 6.04E-04 4.4723
pair_coeff 5 5 lj/cut 1.54E-01 3.1627
bond_style harmonic
bond_coeff 1 554.1349 1.0000
bond_coeff 2 554.1349 1.0000
angle_style harmonic
angle_coeff 1 45.7696 109.47
pair_coeff * * coul/long
kspace_style ewald 1e-5
special_bonds coul 0 0 0 lj 1 1 1
for input file :
processors * * *
timer off
units real
atom_style full
timestep 1.0
group water type 5 7
fix wshake water shake 0.0001 20 0 b 2 a 1
fix NPT all npt temp 300.0 300.0 100.0 x 1.0 1.0 1000.0 y 1.0 1.0 1000.0 z 1.0 1.0 1000.0 couple none
Thanks in advance.
Why use pair style hybrid/overlay and not lj/cut/coul/long?
Why this setting?
Why Ewald and not PPPM?
You have atom types without LJ parameters. Have you checked that those atoms cannot come close to another due to their charges?
Thank you it work :)) , i think the problem was the special_bonds coul 0 0 0 lj 1 1 1 command
That doesn’t answer my question(s).
Since I provided help with your problem, please also have the courtesy to answer my questions.
i’m pretty sure i took it directly from here (the layout but not the same parameters)
also when changing ewald to ppm , the simulation become Way much faster
https://doi.org/10.1063/1.5042755
SupplMat.pdf (223.3 KB)
The main issue that I see is that the authors of the paper used wolf summation for coulomb instead of a long-range solver that you are using. Those can be quite different.
It is rather strange that they use the special_bonds command that they do, but that is part of the force field, obviously.
