Dear experts and my fellow LAMMPS users,
I am simulating a pseudo 2d system composed of srd fluid and colloidal particles. The mixture is confined in z-direction by walls. I do not understand why my simulations are getting killed If I use wall/srd to model the walls. I am pasting here the minimum working input deck:
# 3d confined PBPs and fluid
# with WCA potential
variable rand equal ceil(random(1423,8674437,756349))
variable temp string 1.0
units lj
atom_style sphere
atom_modify first big
boundary p p f
#newton off
region box block 0 128 0 128 0 12
region plane block 0 128 0 128 6 6
create_box 2 box
create_atoms 1 random 65 ${rand} plane overlap 11
set type * diameter 10.0
set type * mass 75.0
group big type 1
velocity big create ${temp} ${rand} loop geom
velocity big set NULL NULL 0.0
# more careful with neighbors since higher diffusion in abps
neighbor 1.0 bin
neigh_modify every 1 delay 1 check yes
# WCA potential (purely repulsive)
pair_style hybrid/overlay lj/cut 4.489848 yukawa/colloid 1.4 35 colloid 35 #11.762734
pair_coeff 1 1 colloid 7.3 1 10 10 35 #11.762734
pair_coeff 1 1 yukawa/colloid 20 35 #11.762734
pair_coeff 1 2 lj/cut 1.0 4 4.489848
pair_coeff 2 2 lj/cut 0.0 1.0
pair_modify shift yes
# overdamped brownian dynamics time-step
fix langT all langevin ${temp} ${temp} $(100*dt) ${rand} #omega yes
fix z0 big setforce NULL NULL 0.0
fix step big nve
#equilibration
timestep 0.01
thermo 10000
run 500000
unfix langT
unfix step
unfix z0
#inserting SRD
region fluid block 0 128 0 128 0.1 11.9
create_atoms 2 random 3100 ${rand} fluid
set type 2 mass 1.0
set type 2 diameter 0.0
group small type 2
velocity small create 1.0 ${rand} loop geom
# delete overlaps
# must set 1-2 cutoff to non-zero value
delete_atoms overlap 5 small big
write_dump all atom dump.atom
reset_timestep 0
neighbor 0.1 multi
comm_modify mode multi group big vel yes
neigh_modify include big
timestep 0.01
fix 3 small srd 10 big ${temp} 2.0 ${rand} &
radius 0.88 shift yes ${rand} search 0.2 overlap yes collision noslip inside warn tstat yes
fix zwalls small wall/srd zlo EDGE zhi EDGE
# main run
#velocity big set NULL NULL 0.0
fix step big nve
run 100000
reset_timestep 0
thermo 10000
dump dump3 big custom 1000 pbp_prod.lammpstrj id type x y
run 2000000
Actually, I could not retrieve any error message. My workstation stalls and then after coming to life, my screen simply displays “BAD TERMINATION OF YOUR APPLICATION”. I am trying to figure out the error. The version is 28 Mar 2023.
I do now understand the memory issue, but why? It is related to neighbor lists? Without the walls, there are no such memory issues. Creating SRD particles could never be the problem.
Switching to a wall/reflect style, setting a processors * * 1 grid, and running on 4 cores decreases the memory usage to 20 GB.
Also, on the main run, you may want to apply the NVE integrator to all particles, instead of just the group big.
Here is the breakdown of time after a short run with 2000 steps:
Loop time of 74.4415 on 4 procs for 2000 steps with 2622 atoms
Performance: 23212.874 tau/day, 26.867 timesteps/s, 70.445 katom-step/s
99.9% CPU use with 4 MPI tasks x no OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.028419 | 0.030002 | 0.033324 | 1.1 | 0.04
Neigh | 0.018435 | 0.019085 | 0.019639 | 0.4 | 0.03
Comm | 0.044021 | 0.047419 | 0.049811 | 1.1 | 0.06
Output | 0.0024935 | 0.0025975 | 0.0027012 | 0.2 | 0.00
Modify | 74.336 | 74.337 | 74.338 | 0.0 | 99.86
Other | | 0.00583 | | | 0.01
I have to implement no slip boundary conditions to my SRD particles.
My main run corresponds to SRD+COLLOIDS mixture, where Colloids needs integrator for the positions updates and small SRD particles are updated via fix srd.
I think I need to be more informed about how walls are coded here! Why such memory demand exploded by just inclusion of walls is something that I don’t understand at the moment.
Thanks for the clarification, I am by no mean expert on granular simulations, but happy to learn something about it. My point here is not to thinker with your simulation, but to understand what causes the problems you reported. From what I see:
The wall/srd increases significantly the memory consuption.
The breakdown of time usage shows that the comm_modify is eating all the computing time.
Many thanks @hothello for your genuine efforts. I have in haste have posted this problem thinking of getting some direct help. Thank you for pointing out to the stats and now will try to solve this problem.
Well, I am integrating hydrodynamics explicitly using SRD technique into my colloidal dispersion. I am trying to model an experimental observation regarding colloidal dispersion in an aqueous solution.
