Dear Lammps user,
I am trying to simulate a kerogen molecules with reax force field. However, the simulation stops before finishing. The input script is shown below:
ReaxFF potential for kerogen system
units real
atom_style full
read_data Kerogen_all_types.data
pair_style reax/c control.reax_c.rdx
pair_coeff * * ffield.reax 1 1 1 3 1 4 5 2 2
compute reax all pair reax/c
variable eb equal c_reax[1]
variable ea equal c_reax[2]
variable elp equal c_reax[3]
variable emol equal c_reax[4]
variable ev equal c_reax[5]
variable epen equal c_reax[6]
variable ecoa equal c_reax[7]
variable ehb equal c_reax[8]
variable et equal c_reax[9]
variable eco equal c_reax[10]
variable ew equal c_reax[11]
variable ep equal c_reax[12]
variable efi equal c_reax[13]
variable eqeq equal c_reax[14]
velocity all create 300.0 4928459 rot yes dist gaussian
neighbor 2.5 bin
neigh_modify every 10 delay 20 check yes
thermo_style custom step temp epair etotal press &
v_eb v_ea v_elp v_emol v_epen v_ecoa v_ehb &
v_et v_eco v_ew v_ep v_efi v_eqeq
thermo 2000
timestep 0.1
fix 1 all nvt temp 300.0 300.0 10.0
fix 2 all qeq/reax 1 0.0 10.0 1.0e-6 reax/c
dump 1 all xyz 4000 kerogen_reax_nvt_300.xyz
dump 2 all image 40000 kerogen_reax_nvt_300.*.png type type
fix 1 all nvt temp 300.0 300.0 0.1
run 200000
write_restart kerogen_reax_nvt_300.restart
the log file only stop at timestep at 32000.
Working directory is /home/she8/heshuai/Kerogen_Reax
LAMMPS (9 Dec 2014)
Reading data file …
orthogonal box = (-30.2521 -56.0234 -2.2804) to (46.4637 13.2215 32.3103)
8 by 4 by 2 MPI processor grid
reading atoms …
1272 atoms
Finding 1-2 1-3 1-4 neighbors …
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
Setting up run …
Memory usage per processor = 11.5855 Mbytes
Step Temp E_pair TotEng Press eb ea elp emol epen ecoa ehb et eco ew ep efi eqeq
0 300 -181229.84 -180093.26 32122.588 -243680 -2365.8896 2.1979658 0 184.82506 2.5577597e-11 -10.212182 1498.2505 -5085.287 65566.647 -2663.7653 0 1175.0794
2000 286.67841 -188949.85 -187863.73 356.52786 -243862.16 -2156.7883 56.292354 0 164.96268 8.959166e-11 -3.3245532 904.08541 -5176.849 58688.057 -2569.914 0 1088.2415
4000 299.54994 -189035.47 -187900.59 416.06742 -243934.87 -2228.4048 68.559834 0 163.27657 7.1295579e-11 -4.7748924 882.9766 -5175.387 58797.055 -2599.2197 0 1110.1247
6000 287.72074 -189090.37 -188000.31 -379.95504 -244094.27 -2171.9048 103.39324 0 165.44434 4.8539501e-11 -4.0159185 897.36408 -5173.8053 58789.435 -2635.6044 0 1139.5191
8000 298.01455 -189158.45 -188029.39 752.50269 -244401.55 -2136.3645 128.32376 0 167.62356 4.88234e-11 -6.5985255 869.04561 -5171.2917 59014.912 -2648.663 0 1156.0625
10000 296.2204 -189134.09 -188011.83 516.50878 -244236.24 -2110.145 119.10715 0 167.52562 9.0670668e-11 -7.6120035 900.41581 -5182.0204 58811.347 -2649.5746 0 1158.0686
12000 304.84436 -189216.41 -188061.47 386.4574 -244341.6 -2061.5708 89.076726 0 174.90782 1.0664177e-10 -7.5717835 883.69282 -5201.4379 58869.361 -2618.9704 0 1127.7036
14000 307.88731 -189138.03 -187971.57 -779.19199 -244206.55 -2175.9406 128.95918 0 163.61546 7.1725761e-11 -3.8473744 881.59257 -5177.0763 58839.471 -2679.1898 0 1171.59
16000 295.80175 -189222.79 -188102.11 7.2030537 -244223.25 -2116.0606 109.53121 0 165.43988 8.1966638e-11 -5.3458455 930.62944 -5173.6076 58751.179 -2653.4255 0 1150.8208
18000 300.80633 -189134.7 -187995.06 360.05664 -244274.11 -2065.1255 113.74046 0 166.86256 5.8863147e-11 -3.8891549 954.81631 -5179.7616 58774.425 -2658.5246 0 1155.6241
20000 288.97774 -189195.48 -188100.66 604.73976 -244206.13 -2114.0619 121.40347 0 169.58035 5.0388421e-11 -6.7169659 923.14055 -5188.2738 58740.733 -2666.648 0 1161.693
22000 293.27909 -189191.93 -188080.81 71.562863 -244282.19 -2058.0083 84.326903 0 169.69207 3.7907976e-11 -5.3607125 927.86398 -5193.1068 58817.124 -2677.379 0 1166.5926
24000 296.72032 -189185.64 -188061.48 249.55833 -244290.79 -2109.2467 113.14052 0 167.80104 6.3749353e-11 -3.396529 941.26156 -5183.3926 58867.08 -2664.2813 0 1161.3865
26000 310.79374 -189235.37 -188057.89 -1354.2312 -244242.77 -2123.6401 122.42294 0 168.22481 8.8778034e-11 -4.549328 901.5706 -5193.6625 58783.591 -2665.4066 0 1161.2559
28000 310.08212 -189194.63 -188019.85 -480.68235 -244477.07 -1954.7772 107.57739 0 170.80374 8.531817e-11 -8.0591895 921.80106 -5198.207 58868.248 -2670.4034 0 1166.4056
30000 298.69168 -189203.39 -188071.76 519.52753 -244440.6 -2064.477 120.59149 0 167.6916 3.9003067e-11 -11.278444 910.85196 -5189.0075 58918.659 -2679.1912 0 1173.91
32000 300.2762 -189226.3 -188088.68 -1805.8711 -244437.21 -2013.2508 133.59586 0 167.04812 4.0642989e-11 -9.6356189 888.87112 -5190.4641 58850.548 -2683.172 0 1179.8703
Could someone give me some advice? Thanks.
Regards,
Shuai
Dear Lammps user,
below:
# ReaxFF potential for kerogen system
units real
atom_style full
neighbor 2.5 bin
thermo 2000
timestep 0.1
# fix 1 all nvt temp 300.0 300.0 0.1
run 200000
# write_restart kerogen_reax_nvt_300.restart
LAMMPS (9 Dec 2014)
Reading data file ...
reading atoms ...
1272 atoms
Setting up run ...
efi eqeq
1175.0794
1088.2415
1110.1247
1139.5191
1156.0625
1158.0686
1127.7036
1171.59
1150.8208
1155.6241
1161.693
1166.5926
1161.3865
1161.2559
1166.4056
1173.91
1179.8703
No, not with this limited information. Also your input and output don't
add up. The pair_coeff command of the 9 Dec 2014 version already reads
element names not numbers. Double check the version of LAMMPS you are
using.
Ray
