Hello.
I am writing to report an issue that I encountered when using the read_restart command in LAMMPS. I attempted to perform some calculations that are completely identical, with the only difference being the number of CPU cores used. However, even with this change, I noticed that there were small differences in the calculation results.
I suspect that these differences may be caused by some minor errors in the parallel computation process, as there is no use of random number generator in the input files. Therefore, I am wondering if there is any method to avoid this issue, such as using higher precision in the computation.
For your reference, I am using Ubuntu 22.04 as my operating system and the LAMMPS version is lammps-23Jun2022.
Thank you for your assistance in advance.
