Snap
i tried installing ML-SNAP package in lammps through cmake, but its not getting installed properly and am running into this error when i run some examples files from /snap
error:
Unrecognized compute style ‘sna/atom’ is part of the ML-SNAP package which is not enabled in this LAMMPS binary. (src/modify.cpp:1289), Last command: compute sna all sna/atom 1 0.99 363 6 1.3 1.0 r0 0 quadratic flag 0 bzeroflag 0
I ran this code from the source file /mylammps
cmake -S cmake -B build -D PKG_ML-SNAP=yes
and make from /mylammps/build folder
but after installation, when i used lmp_serial -h to verify if its installed, the installed packages space is empty
When you build LAMMPS with CMake the way you did, the LAMMPS executable is in the “build” folder under the name “lmp”. You can check its status by typing “./lmp -h” in the build folder.
When you run “lmp_serial -h” you are picking up some other LAMMPS executable, possibly one build with the traditional make build procedure and then either modified your PATH environment variable or copied it to a folder already listed in PATH.
A typical case of PEBCAC
