This is my code to add forces to lammps
LAMMPS_NS::LAMMPS *lmp;
// custom argument vector for LAMMPS library
const char *lmpargv {“liblammps”, “-log”, “none”};
int lmpargc = sizeof(lmpargv)/sizeof(const char *);
// explicitly initialize MPI
MPI_Init(&argc, &argv);
// create LAMMPS instance
lmp = new LAMMPS_NS::LAMMPS(lmpargc, (char **)lmpargv, MPI_COMM_WORLD);
std::cout << "LAMMPS version ID: " << lmp->num_ver << std::endl;
writeInitialConfig(“init_config.txt”);
lmp->input->file(“infile.lmp”);
int natoms = static_cast<int>(lmp->atom->natoms);
int nlocal = lmp->atom->nlocal;
double **f = lmp->atom->f;
double **x = lmp->atom->x;
int *id = lmp->atom->tag;
for (int step = 0; step <= FTIME; ++step)
std::unordered_map<int, Vert*> id_to_vert;
for (int i = 0; i < total_verts; ++i)
id_to_vert[verts[i]->id] = verts[i];
for (int i = 0; i < nlocal; ++i)
int atom_id = id[i];
Vert* v = id_to_vert[atom_id - 1];
v->setCoord(x[i][0], x[i][1], x[i][2]);
v->force[0] = v->force[1] = v->force[2] = 0.0;
if (step % OUTPUT_FREQ == 0)
trials = 0;
do
prob = udist();
ran1 = (int) (udist() * total_edges) + 1;
cout << ran1 << endl;
if(prob<0.5)
flipSuccess = edgeFlip(edgef[ran1]);
Nflip += flipSuccess;
else
flipSuccess = edgeFlip(edgeb[ran1]);
trials++;
} while (!flipSuccess && trials <=MAX_TRIALS);
if(flipSuccess)
cout <<"Vertices fliped : "<<vertices[0] <<" "<<vertices[1] <<" "<<vertices[2] <<" "<<vertices[3] <<endl;
stringstream group_cmd;
group_cmd << "group my_group id " << vertices[2] << " " << vertices[3];
lammps_command(lmp, group_cmd.str().c_str());
lammps_command(lmp, "delete_bonds my_group multi remove");
lammps_command(lmp, "group my_group delete");
stringstream bond_cmd;
bond_cmd << "create_bonds single/bond " << 1 << " " << vertices[0] << " " << vertices[1];
lammps_command(lmp, bond_cmd.str().c_str());
lammps_command(lmp, "write_data restart.txt");
lmp->input->one("run 0 pre yes post no");
// Caculate bending Forces on each point
for (int l = 0; l < total_verts; l++)
if(verts[l]->boundary)continue;
for (int j = 0; j < verts[l]->num_neighbors; j++)
int n_id = verts[l]->vertex[j]->id;
if(verts[n_id]->boundary)continue;
bendingForce(n_id, l);
f[i][0] += v->force[0];
f[i][1] += v->force[1];
f[i][2] += v->force[2];
lmp->input->one("run 1 pre no post no");
if (step % OUTPUT_FREQ == 0) outputVTKFile(step);
Also this is my input script
units lj
atom_style bond
boundary f f f
read_data init_config.txt extra/bond/per/atom 10 extra/special/per/atom 25
reset_timestep 0
bond_style harmonic
bond_coeff 1 500 1.2
pair_style lj/cut 1.12246
pair_coeff 1 1 1.0 1.0 1.12246
pair_modify shift yes
special_bonds lj 0.0 1.0 1.0
timestep 0.0005
neighbor 1 bin
comm_modify cutoff 3.0
min_style cg
minimize 1e-6 1e-8 10000 100000
fix 1 all nvt temp 1.0 1.0 1.0
