I am trying to use the SOAP featurizer you have implemented recently (thanks guys!), but I am getting error messages complaining there is no ‘composition’ attribute in the Structure object. However, I haven’t been able to figure out how to include ‘composition’ in a pymatgen Structure object - or perhaps I am misunderstanding something here.
The “fit” operations in matminer require the data as input, which is different than the “featurize_dataframe” operation that takes the name of the column.
From:[email protected] Sent: Sunday, May 5, 2019 4:28 AM To: matminer Subject: SOAP featurizer - ‘str’ object has no attribute ‘composition’
Hi there,
I am attaching here a screen grab.
Many thanks,
Linjiang
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
For more options, visit https://groups.google.com/d/optout.
Thanks a lot for your quick reply - greatly appreciated.
I have changed it as advised, but I am seeing a different error as shown below, which is all I use to set a SOAP featurize (I must have missed something here)…
Subject: RE: SOAP featurizer - ‘str’ object has no attribute ‘composition’
Hello Linjiang,
Hi there,
Many thanks,
Linjiang
[Screenshot from 2019-05-05 10-26-34.png]
If you look in the requirements-optional.txt file in matminer we specify the version we use: dscribe==0.1.8
If you are using a newer version of dscribe which does not have the “normalize” argument for SOAP, this will be the source of the error. If this is the case, we would appreciate a pull request on the matminer repo to reflect changes in newer versions of dscribe!
I’ve also updated the implementors list and citations() function for the SOAP descriptor to better convey this.
Hope it all works now!
On Tuesday, May 7, 2019 at 9:05:40 AM UTC-7, Logan Ward wrote:
Hello Linjiang,
Try changing:
“soap_fit.fit(strucs_dataset, ‘Structure_obj’)”
to
“soap_fit.fit(strucs_dataset[‘Structure_obj’])”
Logan
Hi there,
Many thanks,
Linjiang
