I have an issue with my script. It runs with no warnings whatsoever however when I go to visualise the simulation, the water droplet doesn’t interact with the surface. Instead it just moves about in its own region. Does anyone know why this is? scrip.txt (2.5 KB)
For future reference. If you want constructive help from this forum, you have to play by the “rules” that the people that usually respond here have agreed upon. Just posting your script and stating that it does not do what you want and asking people to explain why is definitely not what you should do.
Be concise and specific; do not make any assumptions about how easy it is to find a solution
What you should not expect from this forum
Be sure to research your problem before posting
Your system just does what your force field, input settings, and equations of motion say
If you don’t, you are likely to get responses that are not helpful or no responses at all.
Please be mindful that people here volunteer their time and thus don’t act as if everybody was out here just to serve you every time something does not work as you expected it. This is first and foremost the job of your tutor and an online forum cannot be a replacement for that.
I’m sorry will follow from now on. How is it that I have no forces between? I have my buckingham potential which interacts the two together? I’m sorry for being a pain
