Dear LAMMPS Experts and users
I want to simulate a system that contains a ternary eutectic salt mixture with a composition of 46.5% LiF + 11.5% NaF + 42% KF (FLiNaK).
At first, for my initial configuration, I follow the instructions below article,
https://pubs.acs.org/doi/10.1021/acs.jpcb.2c06915?ref=pdf
As they suggested, to reach a ternary mixture, LiF, NaF, and KF crystals should be placed beside each other in a simulation box and heated under NVT up to a much higher temperature (3000K). After reaching a fine mixed and melt system, it has to be cooled down to the desired melt temperatures via NPT. Later the system must be relaxed and then the properties can be calculated.
I did these steps one by one and fortunately, I could regenerate the closed results to validate/verify my simulations.
But after that, I encountered a big problem. This cooling and equilibrating just worked for melt temperatures and when I cooled it below the melting point I couldn’t capture any phase changes (e.g. Jump in energy, enthalpy, density, etc.) and reach a solid phase in solid temperatures. I observed something like supercooling or a lake of nucleation.
I have read the forums, similar articles, etc, and done lots of chances according to recommendations (increase/decrease cooling rate, cool to a much lower temperature, increase/decrease equilibration time, …) but none of them worked.
Besides I have some other problems which I should explain:
⁃ As I explained I have to heat my system first to reach my mixture so my well-mixed and equilibrated system will occur in the cooling process. I need to capture solidification and phase change in the cooling process and I can’t capture only melting and phase change during the heating process due to completing the mixing process.
⁃ I need to equilibrate and calculate several temperatures in both solid and liquid phases near melting point so I can’t use a single temperature coexistence method which is commonly suggested to overcome this problem.
Maybe this question is not exactly a LAMMPS technical/coding problem but of course, many experts and experienced people are in this forum therefore sharing any experience, advice, and suggestions would be greatly appreciated.
Best regards
Amir Abdi
