Hi everyone,
I am trying to write a new fix derived from ave/time to compute the variance of data the same way the latter fix computes averages. I’ve given them the generic name fix_variance_time.h/cpp.
In my header file, I’ve changed the style macro to
#ifdef FIX_CLASS
// clang-format off
FixStyle(variance/time,FixVarTime);
// clang-format on
#else
and renamed the class FixVarTime everywhere the FixAveTime name was present. I’ve done this in the .cpp file as well.
However when compiling (using cmake), I get the following error:
error: identifier "FixVarTime" is undefined
(*fix_map)["variance/time"] = &style_creator<Fix, FixVarTime>;;
I understand this comes from the macros and that this happens when compiling the modify.cpp file. But looking at the generated styles_fix.h file, I see that the imported file is correctly named fix_variance_time.h. When looking at where the FixAveTime and FixVarTime where changed using grep, I see no other place where I might have forgotten to change it in both files (this was done automatically using a vim command).
Is there anything I am missing here? Where could this error stem from? Any help is welcome since I am a bit unsure on how these macro work and where to look.
