Hi all,
This may come in pretty general for LAMMPS mailing list, but I thought
I would want to give it a try... I am trying to debug my code to allow
it running with yes-user-intel when compiling LAMMPS with Intel's
architecture. At the moment, running on fewer number of processors per
node seems to work fine, but there is memory error when trying to run
on large number of nodes.
I have tried debugging my code with valgrind command as followed:
valgrind --log-file="out.txt" mpirun -np 28
$LMP_SRC/lmp_intel_cpu_openmpi < flow.lmp -var dname data-wall &>
out-err.txt
And the output for out.txt: https://pastebin.com/7tMj7rkt
and out-err.txt: https://pastebin.com/6B62dtmz
At the moment, I'm trying to track down the origin of uninitialised
values (according to some Google's results), and shall slowly work my
way from there. In the meantime, does anyone have some tricks up their
sleeves that could help speeding up the debugging process?
Many thanks,
QT
