Hello everyone, I am working with a high-pressure system (~300 GPa) where pressure effects cannot be neglected. The structures used for training have undergone relaxation at a given pressure. By fitting the enthalpy with icet, I have obtained an effective cluster interaction (ECI) to predict enthalpy. However, I am uncertain about the following aspects:
- To calculate the enthalpy of the random alloy at a given pressure and temperaute (isothermal-isobaric ensembles), I perform Monte Carlo swaps to change alloy configurations, the Metropolis acceptance criterion typically relies on the potential energy difference. Does this imply that I should train an ECI based on potential energy instead? Or would using enthalpy differences in the Metropolis criterion be a valid approach? I have the same question regarding semi-grand-canonical Monte Carlo simulations.
- All training structures have undergone structural relaxation at the same pressure (~300 GPa), resulting in different equilibrium volumes. Based on my understanding, cluster expansion does not explicitly incorporate volume. If I estimate a structure with a low enthalpy using my fitted ECI, does this mean that the enthalpy given by the ECI corresponds to that structure at my training pressure (~300 GPa)?
Thanking you in advance for your help.
