Hi dear LAMMPS users,
In my simulation model, I have 9 kinds of atoms. But I only consider 3
kinds of atoms (A B and C) for simplicity here. My pair_style is
lj/cut/coul/long. The unusual aspects of my model are as follows:
1.For atom pair AA AB AC and BB BC, the lj cutoff distance is R1
2.and for atom pair CC, the lj cutoff distance is R2.
3.And the global coul cutoff is 12A, the lennard-jones parameter can
be computed through pair_modify command, but the cutoff cannot.
To achieve this, I was wondering which method can achieve what I want?
And my input script are as follows, and I have three questions
following each “#”, really appreciate for your kindly help:
Method1:
Read_data atoms.data
Pari_style lj/cut/coul/long R1 12
Pair_modify mix geometric
#question1: Now the LJ parameters for AA AB AC BB BC CC are correct
and the cutoff distance for AA AB AC BB BC is correct(equals R1 here),
but the cutoff distance for atom pair CC is not correct(equals R1 here
but the correct cutoff is R2). So next step I will set it explicitly.
I was wondering whether the pair_modify mix command will take into
account the new pair_coeff for atom CC which I set explicitly on the
next step. So the cutoff for AC and BC is (R1+R2)/2.
Pari_coeff 3 3 0.21 2.96 R2
#question2: Because I want to set the cutoff distance for AC and BC to
R1 explicitly(don’t through pair_modify mix…). So I set pair_coeff for
CC after mix done. I was wondering whether the order between
pair_coeff and pair_modify will influence the results.
Method2:
Pair_style lj/cut/coul/long R1 12
Pair_coeff 1 3 0.56 3.4 R1
Pair_coeff 2 3 0.53 3.5 R1
#question3: I think this method can achieve what I want, cause I set
AC BC CC explicitly and use mix geometric to compute other lj
parameter (AB) which I haven’t set. But when there are many kinds of
atoms, I need to compute and set every lj parameter explicitly. So it
maybe tedious in my simulation. So I was wondering whether method1 can
get the same result as method2 or is there some alternative method.
Thanks for your advisement
Looking forward to your reply.
Sincerely,
Shusen Guo
