Some ternary phase diagrams like “Co-Fe-V” don’t render in the phase diagram app. It is possible this is because there are no ternary compounds in this space, however the phase diagram should still render using the binary compounds.
hello @Anubhav_Jain
In this example, there are three possible binaries for the sub chemical systems: Co-Fe, Fe-V, and Co-V,
do you mean it should fall back to any one of the three cases?
Or do you mean it should render a 3D plot with the three binaries as three endpoints?
If I type “Co-Fe-V” for the phase diagram, it should render a ternary (triangle) phase diagram with endpoints at Co, V, Fe - just like any other ternary phase diagram. The only difference is that the phase diagram would have no phases (points/dots) in the middle of the phase diagram, but this is completely fine.
Currently, that phase diagram doesn’t render at all, it just glitches and refuses to do anything.
I see, that makes a lot of sense. This would be an improvement worth making, thanks for suggesting that. @Anubhav_Jain
