I have used a dump atoms command to dump a txt file.Now I want to sort the atomIDs in the file. So I used
dump 1 all atom 100 dump.run.txt
dump_modify 1 sort atom ID
But I am getting an error message:Expected integer parameter in input script or data file (…/dump.cpp:856)
The sorting of the atoms are very essential for my work. So please help.
From the doc page:
*sort* arg = *off* or *id* or N or -N
off = no sorting of per-atom lines within a snapshot
id = sort per-atom lines by atom ID
N = sort per-atom lines in ascending order by the Nth column
-N = sort per-atom lines in descending order by the Nth column
Ray
Got it.Thank you very much.
Many thanks sir.I have changed it and its working now.
