special_bonds_dihedral_yes
Dear all: I'm using 'dihedral yes' to remove the effects of
special_bonds lj 0.0 0.0 0.0 on 1-4 neighbors that are not the
first-last atoms of any dihedral. However, in my case, the number of
1-4 neighbors becomes 0 after trimming the 1-4 neighbor list using
'dihedral yes'. This means 'special_bonds dihedral yes' does not find
any 1-4 neighbors that belong to a dihedral, thus "special_bonds lj
0.0 0.0 0.0" would affect all 1-4 neighbors.
The chain topology in my system is:
neighboring atoms along a chain are connected by one type of bonds,
i.e. linear topology,
atom i, i+1, i+2 are explicitly specified as atoms in an angle,
atom i, i+1, i+2, i+3 are explicitly specified as atoms in a dihedral,
then 1-5 neighbors (i, i+4) along the original chain are connected by
a different type of bonds.
Why does 'dihedral yes' fails to work with the original 1-5 neighbors
connected by additional bonds?
Thank you for your help.
Ting
i feel i sound like a broken record...
please provide a - preferably small - example
input that demonstrates the problem.
impossible to argue these things just hypothetically.
there are far too many things that go wrong.
Hi Axel: Thank you for your reply. The following is part of my input
script. It specifies the tables for different potential fields.
Dear T GE,
Dihedral keyword is affecting the 1-4 neighbors which are not defined in the system.
See the document below.
Thanks.
Special_bonds does not use the dihedral list to identify 1-4 neighbors
and reweight their interaction. Instead it finds 1-4 neighbors based
on the topology of bond connectivity. With dihedral yes, it removes
1-4 neighbors that are not first-last atoms of any dihedral from the
neighbor list. What remains should be a list of dihedral atoms, and
special_bonds would affect the interaction between them, as expected .
My concern is that in my case, if you look at the output file, the
number of 1-4 neighbors after the trim is zero. This means
special_bonds (special.cpp source file) does not find any 1-4 neighbor
that belongs to a dihedral. Therefore, I am worried that the
interaction within dihedrals is not reweighted. (In my case, the
normal lj interaction not deactivated.)
I would expect the number of 1-4 neighbors after the trim to be twice
the number of dihedrals. Just as the number of 1-3 neighbors after the
trim is twice the number of angles.
I tried to understand the protocol used to track 1-2, 1-3 and 1-4
neighbors in the special.cpp file. Not easy to follow...
Could someone please explain the way special.cpp trims the 1-4 neighbor list?
Ting
2013/1/22 Chang Woon Jang <[email protected]...>:
T GE
I am sorry that I do not understand what you said.
With the LAMMPS document, I will explain what is going on your system.
From your data file, for example, you defined like
Dihedrals
1 3 1 2 3 4
2 1 2 3 4 5
For 1 to 5 atoms, if you did not define 2 1 2 3 4 5, pairwise interaction between atom 2 and atom 5 interaction should be affected with full weighting factor 1.0 because you used “dihedral yes”.
However, you did define this dihedral term 2 1 2 3 4 5. So, the pairwise interaction between atom 2 and atom 5 is affected by special_bonds lj 0.0 0.0 0.0.
As I understood from your data file, you defined all dihedrals from atom 1 to atom 4608 in sequence. Therefore, your “lj values (0.0 0.0 0.0)” made the neighbors 1-4 0 after dihedral trim (I guess the wording “after dihedral trim” means using and after “special_bonds” command). Your keyword “dihedral yes” did not affect your system.
I may be wrong. But with your data file and setting special_bonds in your input file, it makes sense to me based on the LAMMPS document.
He, Axel, will explain it anyway. I am also curious of my analysis of your output.
Thanks.
Changwoon Jang
this is *useless* since it is incomplete.
T GE
agreed. it is very confusing and it doesn't make much sense.
but it seems to me the problem is really a badly designed
molecular model in combination with an incomplete
understanding of how exclusions are applied.
Dihedrals
1 3 1 2 3 4
2 1 2 3 4 5
factor 1.0 because you used "dihedral yes".
0.0 0.0.
this is correct. which means that both should be listed as "special dihedrals".
to atom 4608 in sequence. Therefore, your "lj values (0.0 0.0 0.0)" made the
neighbors 1-4 0 after dihedral trim (I guess the wording "after dihedral
trim" means using and after "special_bonds" command). Your keyword "dihedral
yes" did not affect your system.
this is not a correct analysis of the situation.
the real problem arises from the comment about
"adding bonds to model 1-5 neighbors".
from what i understood, there is not only a straight chain of bonds,
but *additional* bonds between atoms 1 and 5, 2 and 6, 3 and 7
and so on. *this* is the origin of the problem, because of that, the
bond topology is *massively* changed. the atoms 1,2,3,4,5 now also
form a ring and thus there are suddenly more topological angles
and dihedrals (e.g. 4,5,1 becomes a topological angle, and thus
the 1-4 interaction would be counted as both, a 1-3 and a 1-4 interaction.
the 1-3 takes precedence over the 1-4, so the dihedral 1,2,3,4 is
not even considered for a 1-4 interaction.
yes, LAMMPS works correctly and as documented.
in order to demonstrate this, i am creating a set of
three data files with 3 different topologies made from
a linear chain of 11 atoms. a) has all topological dihedrals
defined, b) has one dihedral removed and c) has bonds
between 1-5 pairs added. the attached input script now
runs LAMMPS through the process of building the exclusions
for 3 special_bonds settings. default, dihedral yes and angle+dihedral yes
have a look and see.
p.s.: the attached files may also serve as an example,
how one can write minimal example inputs that demonstrate
how a feature does (not) work.
this was done my slightly modifying the VMD script code from here.
https://sites.google.com/site/akohlmey/software/topotools/topotools-tutorial---part-1
in.chain (2.23 KB)
data.chain-c (1.25 KB)
data.chain-b (1.19 KB)
The following is a complete input script and the datafile, which
demonstrate that special_bonds doesn't work for the loop structure I
use. The structure is a single chain 1-2-3-4-5-6, with 1--5 and 2--6
connected. According to the screen output, 1-4 neighbors after the
trim is zero. My understanding is that this means special_bonds would
not affect the dihedrals I specified in the datafile.
The reason why I did this is that I need a pairwise potential between
1-5 neighbors that is different from the rest pairwise potential. What
I did before is modifing LAMMPS to calculate pairwise potentials based
on the atom IDs. If two neighbors belong to the same chain and are
1-5 neighbors, then they interact with a second pairwise potential.
I was wondering whether connecting 1-5 neighbors with tabulated bonds
(with large cutoff) can be another way to add special 1-5 pairwise
interaction. That's why I tried the wired loop structure. Seems that
the whole topology is complicated by this structure, and it doesn't
work.
Ting
T GE,
In your sample example, you defined pairwise cutoff distance 1.5 (e.g., lj/cut 1.5) but the pairwise distance between atom 1 and atom 4 is 3.
1 1 1 0.0 0.0 0.0
4 1 1 0.0 3.0 0.0
(I GUESS) That is why the interaction between atom 1 and atom 4 did not happen.
Thanks.
Changwoon Jang
this is wrong. due to the additional bonds
you a) exclude the 1-5 non-bonded interaction
since it becomes a bond and excluded due
to a scaling factor of 0.0 and b) turn the 1-4
interaction of the dihedral 1-2-3-4 into a 1-3
interaction of the (topological) angle 1-5-4,
which is also excluded due to the scaling
factor of 0.0. the topological dihedrals remaining
before the trimming are *only* those including
the 1-5 bond (and 2-6) and since those are not
defined they all get removed from the list of
excluded interactions.
work.
no, it *cannot* work. the problem is that you do this with a bond.
i can see multiple ways to support this, depending on how much
effort you want to invest and how clean a solution you want.
a) add a new interaction class for 1-5 interactions with support for
    excluding them, too. that would be a *huge* amount of work
    since you need to update the majority of files that are part of
    lammps.
b) write a pair style that supports two parameter sets for a given
   pair of atom types and you pick the one you want based on
   both atoms having the same or a different molecule id.
   this is a some additional work but probably the cleanest solution.
c) write a custom angle not bond style (so it doesn't add to the
   bond topology) that then ignores the middle atom and implements
   the modified pair interaction by applying the *difference* to the
   regular non-bonded interaction for atoms of those types.
   this is probably the least amount of programming, but
   more work later.
d) find and modify a different code than lammps.
    naaawwww....
Thank you, guys. Now I see why special_bonds works for the loop structure.
As for adding special 1-5 interaction, I've already managed to modify
LAMMPS to support the feature in my system. With bonds connecting 1-5
neighbors, I just want to find another way of doing this.
You say "it *cannot* work. the problem is that you do this with a
bond." Is there anything that immediately excludes this option? I can
see the bond length could be a problem, but if I tabulate the bonding
potential and use a large cutoff, it still doesn't work?
Ting
again, you are not making sense here.
i already explained in detail and with giving
examples why it cannot work... *twice*.
and gave you suggestions for workable
alternatives.
i am not going to explain it a third time.
i wouldn't know which language to use
without becoming offensive.
Okay. Thanks.
