Hi Axel,
Thanks for your reply. I think you have answered my question on the special bond command. Just to be doubly sure, top portion of my input script is shown below.
I have 2 atom types in the structure. Type 1 has LJ for 1-1 interaction. Type 2 is bonded harmonically. Type 1 and 2 are harmonically constrained by bonds and angles.
For my study, I sometimes want LJ for 2-2 to be switched on with different values of epilson to run different cases. For convenience, I only change the LJ epilson to different values (including 0) while keeping the “special bonds” set as 1 0 0.
My question is, by setting LJ epilson to 0, does that has the same effect as setting “special bonds” to 0 0 0 (i.e. only bonded interaction with no LJ)?
Thanks again.
william
#------------READ STRUCTURE-----------------------------------------------------------
units lj
atom_style angle
boundary f p p
read_data final.txt
group end1 molecule 2 10 12 #Fixed End 1
group mid molecule 1 3 4 5 6 7 8 #Simulation atoms
group end2 molecule 9 11 13 #Fixed End 2
#------------LJ Potentials------------------------------------------------------------------
###Potential
#####Intra-atomic Species
#LJ Potential
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0
pair_modify shift yes
#LJ Potential
pair_coeff 2 2 0.0 1.0
#LJ Potential
pair_coeff 1 2 1.0 1.0
#####Harmonic Potential
#between atoms in chain
bond_style harmonic
bond_coeff 1 ${HB1_S} 1.1
#between interface atom in chain and NC
bond_coeff 2 ${HB2_S} 1.1
special_bonds lj 1.0 0.0 0.0
#####Angles between atoms in Chain
angle_style hybrid harmonic cosine
angle_coeff 1 cosine ${HA1_S}
#Angles between NC and interface atom
angle_coeff 2 harmonic ${HA2_S} 109
