Dear Developers,
I need to specify a single shear stress component and let the system
equilibrate and relax, during which I will monitor diffusion behavior.
I am trying to specify only the xz stress component via fix npt:
fix 1 all npt temp 300 300 100 xz 10 10 1000
but this gives following memory error message:
Signal: Segmentation fault (11)
Signal code: Address not mapped (1)
If I specify at least one diagonal stress component, ie,
fix 1 all npt temp 300 300 100 y 10 10 1000 xz 10 10 1000
then the simulation will run.
From the document page:
The target pressures for each of the 6 components of the stress tensor
can be specified independently via the x, y, z, xy, xz, yz keywords…
If the xy keyword is used, the xy tilt factor will change. A box dimension
will not change if that component is not specified.
Is it possible to specify just one shear stress component and run simulation?
Thank you.
Yiyang
Dear Developers,
can be specified independently via the *x*, *y*, *z*, *xy*, *xz*, *yz*
keywords...
If the *xy* keyword is used, the xy tilt factor will change. A box
dimension
simulation?
is it possible to report a possible bug while also reporting which LAMMPS
version this applies to and whether this behavior can be reproduced with
the very latest development version?
