I have a rather simple question that I can’t seem to find any information on! How do I specify more than one pre_rocket task in my_qadaptor.yaml? I need to do a few different things before running the vasp_cmd on my cluster, including activating my atomate environment, loading vasp, and loading the correct stack environment, which is a total of 4 lines. I tried a few different things, but none of them worked:
First, I tried separating each line with a \n character, like so:
pre_rocket: conda activate atomate_env2\n module load intel/17.0.4\n module load impi/17.0.3\n module load vasp/6.3.0
And the FW_submit.script was written all in one line with the \n still printed. I next tried separating tasks by line:
Once again, this still printed in the submit script as all one line
I then tried enclosing the tasks in curly brackets and separating them by a comma, and I tried enclosing them in square brackets with each task separated by a comma, like so:
pre_rocket: {conda activate atomate_env2, module load intel/17.0.4, module load impi/17.0.3, module load vasp/6.3.0}
and
pre_rocket: [conda activate atomate_env2, module load intel/17.0.4, module load impi/17.0.3, module load vasp/6.3.0]
but again, this just resulted in the exact string being printed to FW_submit.script in one line, and the commands couldn’t be read properly.
So, how does one specify multiple pre_rocket commands? Thanks in advance!
