_Reza
March 31, 2011, 4:53pm
1
I asked about this error “ Incorrect args for pair coefficients”
pair_style hybrid eam/alloy sw lj/cut 4
pair_coeff 1 1 eam/alloy Al99.eam.alloy Al
pair_coeff 2 2 Si.sw Si
pair_coeff 1 2 lj/cut 0.4121 2.3216
and thanks to Mr. Steve. I change the command lines to
pair_coeff 1 1 eam/alloy Al99.eam.alloy Al NULL
pair_coeff 2 2 Si.sw NULL Si
But the problem still exists.
What should I do?
What should I do?
many-body potentials only support the pair_coeff * * syntax. re-read
the manual for details
You need an "sw" before the Si.sw. This will be
obvious, and I'm going to say it to the whole list,
if whenever you get an error related to your input script
then you run LAMMPS as
lmp_foo -echo screen < in.foo
The code will echo the offending line and (in this case)
a moment of staring at it versus the doc page would
tell you the problem.
