Hi lammps users,
I am running a loop in my lammps input file, it operates creating or deleting atoms at the beginning of each loop session. The problem is the simulation is still running, but just give me no out put files after 900 runs in the first loop. I am using the current lammps-17Nov16 version with rigid and MISC package compiled. I tried to run the simulation on two different clusters but still got the same problem.
I tried to run with only loop or only create_atoms, the results were able to output normally. I think there should be something wrong with the input file here. I also tried with “thermo modify flush”, but still didn’t work.
I appreciate you help in advance.
Dan
3-d micelle DPD simulation
units lj
atom_style full
timestep 0.006
read_data 24HM_s70_bilyer.data
#read_restart RS2.restart
neighbor 0.5 bin
#neigh_modify delay 2
comm_modify cutoff 30 vel yes
Force-field parameters
define masses and interaction coefficient
mass * 1
Bonded interactions
bond_style harmonic
bond_coeff 1 50 0.18
bond_coeff 2 50.0 0.7
bond_coeff 3 50.0 0.7
bond_coeff 4 1754.8 0.42
angle_style hybrid harmonic cosine/squared
angle_coeff 1 harmonic 50 180.0
angle_coeff 2 harmonic 3 180.0
angle_coeff 3 harmonic 1.5 120.0
angle_coeff 4 harmonic 3 180.0
angle_coeff 5 cosine/squared 13.7 130.0
angle_coeff 6 harmonic 2.25 120.0
Non-bonded interactions
pair_style hybrid/overlay dpd 0.8 1.0 81096
pair_coeff 1 1 dpd 25 4.5 1.0
pair_coeff 1 2 dpd 100 4.5 1.0
pair_coeff 1 3 dpd 100 4.5 1.0
pair_coeff 1 4 dpd 20 4.5 1.0
pair_coeff 1 5 dpd 26.3 4.5 1.0
pair_coeff 1 6 dpd 33.7 4.5 1.0
pair_coeff 1 7 dpd 26.3 4.5 1.0
pair_coeff 1 8 dpd 20 4.5 1.0
pair_coeff 1 9 dpd 26.3 4.5 1.0
pair_coeff 2 2 dpd 25 4.5 1.0
pair_coeff 2 3 dpd 26.3 4.5 1.0
pair_coeff 2 4 dpd 100 4.5 1.0
pair_coeff 2 5 dpd 33.7 4.5 1.0
pair_coeff 2 6 dpd 26.3 4.5 1.0
pair_coeff 2 7 dpd 33.7 4.5 1.0
pair_coeff 2 8 dpd 100 4.5 1.0
pair_coeff 2 9 dpd 33.7 4.5 1.0
pair_coeff 3 3 dpd 25 4.5 1.0
pair_coeff 3 4 dpd 100 4.5 1.0
pair_coeff 3 5 dpd 33.7 4.5 1.0
pair_coeff 3 6 dpd 26.3 4.5 1.0
pair_coeff 3 7 dpd 33.7 4.5 1.0
pair_coeff 3 8 dpd 100 4.5 1.0
pair_coeff 3 9 dpd 33.7 4.5 1.0
pair_coeff 4 4 dpd 25 4.5 1.0
pair_coeff 4 5 dpd 26.3 4.5 1.0
pair_coeff 4 6 dpd 33.7 4.5 1.0
pair_coeff 4 7 dpd 26.3 4.5 1.0
pair_coeff 4 8 dpd 25 4.5 1.0
pair_coeff 4 9 dpd 26.3 4.5 1.0
pair_coeff 5 5 dpd 25 4.5 1.0
pair_coeff 5 6 dpd 100 4.5 1.0
pair_coeff 5 7 dpd 26.3 4.5 1.0
pair_coeff 5 8 dpd 26.3 4.5 1.0
pair_coeff 5 9 dpd 25 4.5 1.0
pair_coeff 6 6 dpd 25 4.5 1.0
pair_coeff 6 7 dpd 100 4.5 1.0
pair_coeff 6 8 dpd 33.7 4.5 1.0
pair_coeff 6 9 dpd 100 4.5 1.0
pair_coeff 7 7 dpd 25 4.5 1.0
pair_coeff 7 8 dpd 26.3 4.5 1.0
pair_coeff 7 9 dpd 26.3 4.5 1.0
pair_coeff 8 8 dpd 25 4.5 1.0
pair_coeff 8 9 dpd 0.0 4.5 1.0 #ligand and receptor
pair_coeff 9 9 dpd 25 4.5 1.0
Groups
group protein type 1
fix 10 protein rigid molecule
group bilayer type 5 6 9
group water type 7
group head type 5 9
region allregion block -35 35 -35 35 -20 10 side in units box
region inner block -33 33 -33 33 INF INF side out units box
region bound intersect 2 allregion inner units box
region upperall block -34 34 -34 34 -7 -6.5 side in units box
region lowerall block -34 34 -34 34 -3 -2.5 side in units box
region upper intersect 2 upperall inner
region lower intersect 2 lowerall inner
region inside block -5 5 -5 5 -20 10 side in units box
group ball region bound
group lfix intersect ball head
create initial velocities
velocity all create 0.8 2984 dist gaussian
Output
thermo 10
thermo_modify lost ignore flush yes
restart 10000 RS1.restart RS2.restart
dump 1 all dcd 1000 dpd.dcd
N-varied DPD
fix 1 all nve/limit 0.02
run 1000
definie local density of lipid and water
variable lcd equal 1.0 #lower critical density
variable ucd equal 1.8 #upper critical density
molecule lipidmolu lipidu.mol
molecule lipidmoll lipidl.mol
run boundary loop
variable a loop 400000
label loop
calculate density for if statement
variable lipidden equal count(bilayer,inside)/13/100/2
variable boundden equal count(bilayer,bound)/13/276/2
variable waterden equal count(water,bound)/276
variable lipidD equal ({lipidden}-{ucd})/{lipidden} variable waterI equal floor((1-{lipidD})27630*3)
variable waterD equal ({lcd}-{lipidden})*26/{waterden}
if "{waterD} < 1" then &
“variable lipidI equal floor({waterD}*276*30*3/26)" &
else &
"variable lipidI equal floor(({lcd}-${lipidden})*276)”
if “{lipidden} < {lcd}” then &
“delete_atoms porosity inside {waterD} 32071 mol yes" &
"create_atoms 0 random {lipidI} 49380 upper mol lipidmolu 67432” &
“create_atoms 0 random {lipidI} 24523 lower mol lipidmoll 76525" &
elif "{lipidden} > {ucd}" &
"delete_atoms porosity inside {lipidD} 73680 mol yes” &
“create_atoms 7 random ${waterI} 90723 inside” &
run 1500
next a
jump in-DPD_NV.ligand loop
