I am using lammps python module to calculate the single point energy of a molecule. Is there any command in the python module of lammps to stop generating the output to the screen of the terminal?
Hi @Utham_Suresh,
If you generate lammps instances using Python, I suggest you read the command-line options section of the manual and pass the arguments suiting your needs using the cmdargs=
argument when instantiating a lammps object.
For example:
lmp = lammps(cmdargs=['-log', 'log.lammps']
Will instantiate the lammps object with the arguments -log log.lammps
. More info in the dedicated section of the LAMMPS python module.
using ,
lmp = lammps(cmdargs=[‘-screen’, ‘none’]) solved the problem.
Thank you
