All,
Relatively new Lammps user. I’ve been running some test cases on my system to check that my input parameters give me a well-behaved system. I’ve run into a very odd issue that I can’t understand.
Background
System is a set of 433 benzene molecules with the Amber gaff2 forcefield. I’ve used this same initial configuration & gaff2 benzene force field previously without any simulation errors. I am now running the following test with it to check pppm and rattle parameters (2 fs time step), all from within the same input script:
- Minimize
- Heat to 293K using fix nve and velocity scaling
- 3 sequential 100 ps NVE runs (fix NVE)
- 3 sequential 100 ps NVT runs (fix NVT)
- 3 sequential 100 ps NPT runs (fix NPT)
Whenever I switch to a different time integration scheme (from heating to NVE, from NVE to NVT, or from NVT to NPT) I remove all active fixes (via unfix), and then start the new fixes I need for the next simulation type. However, I do not remove-then-start fixes if the time step integration is unchanged between blocks (e.g. end of 1st NVE block to beginning of second NVE block)
The above runs fine. The problem is as follows
Strange Behavior
If, instead of running 3 sequential 100 ps NPT runs, I run 4, the simulation crashes upon starting the first NPT block, with an error of “ERROR: Non-numeric pressure - simulation unstable (src/fix_nh.cpp:1069)”. Again, this occurs at the onset of the first NPT block out of four. However, if I only have 3 NPT blocks in the input script, Lammps runs without issue and the simulation energies are completely normal.
So what I don’t understand is why Lammps fails at the onset of the first NPT block in the 4-NPT block simulation, when it has no issue with it (or any of the NPT blocks) for the 3-NPT block simulation.
Also, my understanding is that lammps reads and processes/executes input scripts on a line-by-line basis, as opposed to reading and processing an entire input script before executing), so why would an additional run statement line cause an earlier run statement line to behave differently (and fail, in this case)? Is this some strange floating point math issue?
Other Notes
This issue only occurs for NPT runs when Rattle is enabled. Without rattle, or for constant-volume simulations, I don’t see the issue. Regarding rattle, its occurred for two different rattle tolerances that I’ve tried, 1E-8 and 1E-4. For the simulation that runs successfully (the 3-NPT block), system side length increases by ~0.5% when going from the NVT blocks to the NPT blocks, from 40 angstrom to 40.2 Angstrom (with 0.1 angstrom length fluctuations during the NPT runs)
Lammps Input Script that Fails:
units real
atom_style full
#pair_style lj/charmm/coul/long 8.0 12.0
pair_style lj/cut/coul/long 10.0
pair_modify mix arithmetic
dielectric 1.0
special_bonds amber
bond_style harmonic
angle_style harmonic
dihedral_style charmm
improper_style cvff
read_data benzene.box.data
kspace_style pppm 1E-6
#kspace_modify gewald 0.2935 mesh 40 40 40
group mobile union all
thermo_style custom elapsed elaplong etotal ke pe emol ebond eangle edihed eimp evdwl ecoul elong temp press vol lx ly lz etail ecouple econserve
thermo_modify line multi
thermo 250
thermo_modify flush yes
#Minimization
min_style sd
minimize 0.0001 0.000001 3000 30000
min_style cg
minimize 0.00001 0.000001 7000 70000
write_restart min.pppm.rst
#Heat
reset_timestep 0
timestep 2
fix 2 mobile nve
run 0
velocity mobile create 10 1625586901 mom yes rot yes dist gaussian
fix 1 mobile temp/rescale 500 10 293 1 1
fix rattle all rattle 1E-8 200 50 t 2
#dump 2 all dcd 250 heat.dcd
run 14500
write_restart heat.rst
#undump 2
#NVE 1
unfix 2
unfix 1
unfix rattle
#reset_timestep 0
fix 1 mobile nve
#dump 2 all dcd 500 nve.1.dcd
run 50000
write_restart nve.1.rst
#undump 2
#NVE 2
#reset_timestep 0
#dump 2 all dcd 500 nve.2.dcd
run 50000
write_restart nve.2.rst
#undump 2
#NVE 3
#reset_timestep 0
#dump 2 all dcd 500 nve.3.dcd
run 50000
write_restart nve.3.rst
#undump 2
#NVT 1
unfix 1
unfix rattle
#reset_timestep 0
fix 1 mobile nvt temp 293 293 $(100.0*dt)
#dump 2 all dcd 500 nvt.1.dcd
run 50000
write_restart nvt.1.rst
#undump 2
#NVT 2
#reset_timestep 0
#dump 2 all dcd 500 nvt.2.dcd
run 50000
write_restart nvt.2.rst
#undump 2
#NVT 3
#reset_timestep 0
#dump 2 all dcd 500 nvt.3.dcd
run 50000
write_restart nvt.3.rst
#undump 2
#NPT 1
unfix 1
unfix rattle
#reset_timestep 0
fix 1 mobile npt temp 293 293 $(100.0*dt) iso 1.000000 1.000000 $(1000.0*dt)
#dump 2 all dcd 500 npt.1.dcd
run 50000 <— As is, with 4 NPT blocks, this fails
write_restart npt.1.rst
#undump 2
#NPT 2
#reset_timestep 0
#dump 2 all dcd 500 npt.2.dcd
run 50000
write_restart npt.2.rst
#undump 2
#NPT 3
#reset_timestep 0
#dump 2 all dcd 500 npt.3.dcd
run 50000
write_restart npt.3.rst
#undump 2
#NPT 4 <—Removing this line and everything after causes the script to run without issue
#reset_timestep 0
#dump 2 all dcd 500 npt.4.dcd
run 50000
write_restart npt.4.rst
#undump 2
