Strange spontaneous deformation of an amorphous Si nanobeam after equilibration
Hi all — I need help diagnosing a problem with a LAMMPS simulation of an amorphous silicon (a-Si) nanobeam under bending.
What I’m doing:
I used an LAMMPS workflow that worked fine for crystalline, isotropic Si. To get an amorphous beam I:
  1. Created a small periodic amorphous Si block (a-Si seed) by melting a diamond lattice and quenching, then wrote the result to aSi_tile.data:
# Create a small periodic amorphous silicon block (a-Si seed)
# Units: metal | Potential: Stillinger–Weber | Lattice: diamond
variable       S    equal    4
units           metal
dimension       3
atom_style      atomic
boundary        p p p
# 1. Create crystalline Si seed
lattice         diamond 5.43
region box block 0 ${S} 0 ${S} 0 ${S} units lattice
create_box 1 box
create_atoms 1 region box
mass 1 28.0855
# 2. Define potential
pair_style      sw
pair_coeff      * * Si.sw Si
neighbor        2.0 bin
neigh_modify    delay 10 check yes
# 3. Initialize
timestep        0.001       # 1 fs
velocity        all create 300.0 12345 mom yes rot yes dist gaussian
thermo          1000
thermo_style    custom step temp press pe etotal vol
# 4. Melt crystalline Si
fix             melt all npt temp 300.0 3500.0 0.1 iso 0.0 0.0 1.0
dump            001 all custom 1000 melt.xyz id type x y z
run             50000        # 50 ps
unfix           melt
undump          001
# 5. Quench to amorphous
fix             quench all npt temp 3500.0 300.0 0.1 iso 0.0 0.0 1.0
dump            002 all custom 1000 Quench.xyz id type x y z
run             100000       # 100 ps
unfix           quench
undump          002
# 6. Relax at room temperature
fix             relax all npt temp 300.0 300.0 0.1 iso 0.0 0.0 1.0
dump            003 all custom 1000 relax.xyz id type x y z
run             20000        # 20 ps
unfix           relax
undump          003
# 7. Output periodic amorphous block
write_data      aSi_tile.data          # will be used for replication
dump            1 all custom 200 dump_aSi_tile.lammpstrj id type x y z
  1. Read aSi_tile.data into a second script, replicated it along x to make the beam, set fixed and mobile end regions, equilibrated, then bent the beam by moving the mobile end with fix move:
# LAMMPS script for bending of a silicon nanobeam using fix move
variable   S         equal    4                # Length scale
variable velmob0    equal    0.001
variable velmob     equal (-1)*${velmob0}*${S}
variable iterequi   equal 100000
variable iterrun    equal 5300000
variable T equal 300
variable dt equal 0.001
timestep ${dt}
variable latconst equal 5.431
# Define nanobeam dimensions
variable XNW equal 10*${S}*${latconst}
variable YNW equal 1*${S}*${latconst}
variable ZNW equal 1*${S}*${latconst}
variable L_fixed  equal 0.1*${XNW}
variable L_mobile equal 0.15*${XNW}
variable XEdge    equal ${XNW}+v_L_fixed+v_L_mobile
units           metal
atom_style      atomic
dimension       3
boundary        s s s
# Read a-Si tile and replicate
read_data       aSi_tile.data
replicate       12 1 1         # 12× along x-axis (beam length)
# Define regions and groups
region fixed  block 0 ${L_fixed} 0 ${YNW} 0 ${ZNW} units box
group  fixed  region fixed
variable limX1 equal ${XEdge}-v_L_mobile
region mobile block ${limX1} ${XEdge} 0 ${YNW} 0 ${ZNW} units box
group  mobile region mobile
group  middle subtract all fixed mobile
set region fixed  type 2
set region mobile type 3
dump 009 all custom 1 initial.xyz id type x y z
run 1
undump 009
# Potential
pair_style sw
pair_coeff * * Si.sw Si Si Si
# Minimize and equilibrate
min_style cg
minimize 1.0e-6 1.0e-6 1000 10000
velocity all create ${T} 48284121 mom yes rot yes
fix 1 all nvt temp ${T} ${T} $(100.0*dt)
# Computes...
compute FXeqATOM all property/atom fx
compute FXeq all reduce sum c_FXeqATOM
compute FYeqATOM all property/atom fy
compute FYeq all reduce sum c_FYeqATOM
compute FZeqATOM all property/atom fz
compute FZeq all reduce sum c_FZeqATOM
dump 000 all custom 20000 dumpequilibration.xyz id type x y z
thermo 1000
thermo_style custom step temp pe ke etotal c_FXeq c_FYeq c_FZeq
run ${iterequi}
unfix 1
undump 000
# Production: apply bending
reset_timestep 0
fix 5 middle nvt temp ${T} ${T} $(100.0*dt)
fix 2 fixed move linear 0 0 0 units box
fix 4 mobile move linear 0 ${velmob} 0 units box
variable disp equal (-1)*step*${dt}*${velmob}
compute peatom  middle pe/atom
compute potential middle reduce sum c_peatom
compute keatom  middle ke/atom
compute kinetic middle reduce sum c_keatom
compute FYAtom1 fixed property/atom fy
compute FYfixed  fixed reduce sum c_FYAtom1
compute FYAtom2 mobile property/atom fy
compute FYMobile mobile reduce sum c_FYAtom2
compute mystress all stress/atom NULL virial
compute myTemp middle temp
fix result all ave/time 1 10000 10000 c_myTemp c_potential c_kinetic v_disp c_FYfixed c_FYMobile
thermo 10000
thermo_style custom step f_result[1] f_result[2] f_result[3] f_result[4] f_result[5] f_result[6]
dump 2 all custom 500000 dumpFast.lammpstrj id type xs ys zs c_mystress[1] c_mystress[2] c_mystress[3]
log logFigure.txt
run ${iterrun}
Problem:
Right after the equilibration step (the initial long run), the straight nanobeam spontaneously deforms into a weird shape before I start the bending run. This deformation happens immediately after equilibration and corrupts my bending results.
I would appreciate any hints or help identifying the likely causes. Thanks!
Hi! Please enclose your input script in backticks like this:
your script
So it won’t be messed up by the markup system of the forum (as I spend more time here I start to feel that this should be fixed from the forum side but alright…)
If I’m asked to guess at the current state, I would say it’s probably just the result of your bending test.
Thanks for your suggestion about using backticks. I think my post is now properly formatted.
Regarding your comment about the results, I’d like to mention that the issue actually occurs before the bending starts; it begins right after the equilibrium step.
Thanks, now I understand your problem (I think you meant during the equilibration, not “right after” it).
If the aim is to reduce bending in the equilibration run, then I have two suggestions:
  1. do the replication in your step 1 instead (at the region box block ... command). If you think about it, with how you do the replication now, it’s more likely that e.g. the surface energy of the upper surface is much larger than the lower surface, so the rod would bend upwards; vice versa.
  2. keep the two “terminals” fixed during the equilibration run.
However, considering that the rod is bending noticeably even without load (btw I tested crystalline silicon rod of the same size, and got similar phenomenon to a less extent), I am not sure how meaningful the bending test would be (well, ultimately it depends on what you want to get). If I were you I would reconsider if this model is really desired (and discuss with the supervisor if applicable). For example, if the aim is to reproduce experiments, consider if other materials are also interacting with the rod, or if the rod goes through extra treatments.
This looks like your system isn’t properly equilibrated before you do the replication.
Some comments on your system preparation. This seems quite wrong to me. If you used the same kind of protocol for other studies, the results of those are likely questionable, too, even if the results look ok.
  • there is no point in using a barostat during melting and quenching
  • there is no point in ramping the temperature
  • your melting period appears far too short and I would melt and quench with a dissipative thermostat instead of a Nose-Hoover method which is optimized for maintaining a canonical ensemble of a system in equilibrium
  • using an isotropic barostat makes only limited sense, also, I would consider having only the replication direction periodic and relax only that direction after melting and quenching. To avoid atoms diffusing away, you could add a cylindrical harmonic wall outside the beam, so that atoms leaving the beam can bounce back. If some remain outside the body before final simulation, you can just delete them.
