Hi, lammps-users
I’d like to ask the structure of materials after running lammps.
I have tried to calculate the phonon density of state of graphene on Cu with VACF command.
First I make single-layer graphene on Cu and lammps script called it.
Once I ran lammps and I checked the geometry of materials, graphene layer was not single.
Also, PDOS shape of graphene on Cu was different from literature.
Here is my lammps script and I attached picture and geometry scripts.
I’d really appreciate it if you give some comments.
Jaeyoung Jeong
This is the control script for LAMMPS
echo both
g-cu-4.data (21.6 KB)
Lammps might be confused with the following region commands. Both the Zmin and Zman are same. Try with different values (say 1.48 1.52).
region gra_inter block INF INF INF INF 1.500000 1.500000 units box
Sanjib
Hi, Sanjib
I ran LAMMPS based on your comments as below script but the geometry was the same as attached files.
I wonder where my lammps script was wrong.
Jaeyoung
echo both
Make the input script very simple by deleting almost all fixes/variables. Just read the data file and write dump file with ¡®run 0¡¯ to see if it gives the right geometry. Then add fixes gradually.
Sanjib
Hi, Sanjib
Thank you for your reply.
I checked my lammps scripts based on your comments.
First, I ran the script with “run 0”. Its geometry was fine. Graphene layer was only single as I attached a picture.
I used this script for the first checking. I removed all fixes/variables.
However, I added the relaxation process after the first checking script and run.
Graphene geometry was changed from single layer to double layer but I don’t know where is wrong at relaxation part.
I’d appreciate it if you give me some comments.
Here is the second script with the relaxation part.
echo both
