Dear Team,
i’m new to LAMMPS. I’m running REACTER simulations on LAMMPS for PE based polymers. Befor I successfully completed the REACTER for 1 ns and but when I’m running the longer simulation 10 ns , they are failing with errors like
ERROR on proc 44: Angle atoms 26984 25243 24185 missing on proc 44 at step 3712138
For more information see https://docs.lammps.org/err0005 (src/ntopo_angle_all.cpp:62)
MPI_ABORT was invoked on rank 44 in communicator MPI_COMM_WORLD
Proc: [[7979,1],44]
Errorcode: 1
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
prterun has exited due to process rank 44 with PID 2373136 on node c0711a-s3 calling
"abort". This may have caused other processes in the application to be
terminated by signals sent by prterun (as reported here).
this is the input script that I’m using for the simulation
units real
atom_style full
pair_style lj/cut/coul/long 12.0 12.0
kspace_style pppm 1e-4
bond_style harmonic
angle_style harmonic
dihedral_style fourier
improper_style cvff
special_bonds amber
pair_modify mix arithmetic
dielectric 1.0
neighbor 3.0 bin
timestep 1.0
read_restart nvt.restart
reset_timestep 0
variable runsteps equal 10000000
group OH_wt molecule > 4
molecule mol1 unreacted_template
molecule mol2 reacted_template
thermo 1000
fix myrxns all bond/react stabilization yes statted_grp .03 reset_mol_ids molmap &
react rxn1 all 1 0.0 1.5 mol1 mol2 map02 rate_limit 1 1
fix 1 statted_grp_REACT nvt temp 300 300 100
thermo_style custom step temp pe etotal press density f_myrxns[1]
dump mydmp1 OH_wt custom 1000 linear.lammpstrj id mol type x y z xu yu zu
run ${runsteps}
write_restart restart.run
write_data reacter_done.lmps
I think the crash is happening because of the frequent topology changes. So i want to ask about the strategies to relax local energy spikes during dynamic topology changes
