Hi, I’m doing some surface tension calculations for a Lenard Jhones fluid. I’m interested in pressure, tension, and density profiles. My approach for these profiles is the following
units lj
atom_style atomic
pair_style lj/cut 6
region simblock block 0 90 -100 100 0 90
create_box 1 simblock
region initblock block 0 90 -12.5 12.5 0 90 side in
create_atoms 1 random 10000 3 initblock
mass 1 1
pair_coeff 1 1 1 1 4
neigh_modify every 1 delay 4 check yes
Calculations
compute dvd all chunk/atom bin/1d y center 1 nchunk once units box
compute peratom all stress/atom NULL
fix pressure_profile all ave/chunk 1001000 1 1001000 dvp c_peratom[1] c_peratom[2] c_peratom[3] file tension_profile.dat
The problem with this one and also the other profiles is that the graph is very choppy and not smooth. In many papers, I see that they have a smooth and nice graph. I think the problem is that Lammps is not taking continuous chunks. Is there a way to smooth out Lammps output?
If I try an smaller bin size the output comes out worse.
