Hello, everyone. I hope you are doing well. I’m trying to equilibrate a system consisting of clay, which includes different components like water and silicate layers, etc. After performing several steps of equilibration using the NVT ensemble, I ran the final equilibration using NPT. I should also mention that my system has a relatively large tilt factor. I noticed that the system flips as soon as I run the NPT. However, the results seem okay. Here is the output between the initial and timestep 1000:
Step Temp Press Lx Ly Lz Xy Xz Yz Density Volume TotEng PotEng KinEng
0 297.36351 -7692.1368 26.525123 24.479838 13.785691 -17.01407 0.76472811 -6.2272094 2.4243479 8951.4723 -108825.92 -109510.21 684.28856
1000 316.44015 -346.29438 26.350577 24.215107 13.847519 9.7041279 0.63722181 -6.4078182 2.4560712 8835.8526 -108817.56 -109545.74 728.18744
My question is, is it normal for LAMMPS to flip the structure, or is something wrong, and should I check my parameters and my system? Thank you all for your help
