Hi, I’m having issues with the .cif file output from GULP. The program will happily dump a cif file in, what appears to be, the correct formatting. However, when I go to visualise the structure in Mercury the structure appears squashed, as if the symmetry and/or lattice parameters are incorrectly described:
It seems that the space group is correctly identified but the lattice parameters are for the primitive cell rather than the crystallographic (non-primitive) cell. I have somewhat been able to circumvent the problem by manually editing the lattice parameters to the non-primitive cell but I am still missing half of my structure, see below.
Output cif from gulp, with manually adjusted lattice parameters:
Input structure, before reading into gulp:
How can I fix this? Thanks so much in advance!
