I am trying to do structure relaxation and energy minimization by using Reax, eam and meam poetntials for nanorods (you can see input and data files in attachment).
Before I did both relaxation and minimization for very similar kind structures but for this I am not getting any results, its still running even after 30 hours.
units real
atom_style charge
read_data Nanorod5171 # the input structure
The force field
pair_style reax/c lammps_control
pair_coeff * * ffield Au #number of elements inside the file
fix 9 all qeq/reax 1 0.0 10.0 1.0e-6 reax/c #charge equilibration
optimize box size
fix 1 all box/relax iso 0.0 vmax 0.001
output of structures
dump 1 all xyz 100000 dump.pdef
frequency of energy… output + kind of output
thermo_style custom step pe density press lx ly lz
thermo 10
Minimize
min_style cg # (check it in the manual)
minimize 0.0 1.0e-8 100000 10000000
What could be wrong?
I would really apperciate your comments/suggestions.
in attachment).
after 30 hours.
units real
have you discussed this with your adviser? that should be the first
person to address. after all, this mostly concerns your research and
not any technical issue with LAMMPS. if you believe LAMMPS is at
fault, you need to produce some more convincing evidence.
Yes, I already discussed with my supervisor and he suggested to use different ftol (force units) range i.e. 10^-4 or 10^-6 instead of 10^-8 but the problem remains.
Why I asked here because I did (relaxation and minimization) for very similar kind structures with the very same input description but this time its not working. I think there is problem with criteria selction for minimization so someone can suggest with his experience, it would be great.
I used 10^-8 previously and it worked for all the structures but now it is not working. One question how loose tolerance I can use, is there any limit?
It’s just an input, you can use any value you choose.
Whether it makes sense for what you want to do
is up to you. But it will generally be easier
for the minimizer to converge with a low tolerance.
And that on turn may be an indication that something else is out of whack. However, that is impossible to say in general. You will have to investigate and try to understand.
