Hello, OpenKim users.
Because of the outdated SSL protocol of my server, I have to add MDs from a local source.
And I need some help.
According to section E.5 of the installation manual;
E.5 Adding MDs, PMs, and SMs from a local source directory
The kim-api-collections-management utility allows for the installation of items
from a directory on the local file system. This is useful if you are
developing an item or do not have network access to openkim.org, but already
have the source code downloaded. We'll assume that the item's source code
(including the CMakeLists.txt file, parameter files, etc) you want to install
are in directory "${WORKSPACE}/item-source". Then you simply provide this
directory name instead of the item name.
$ kim-api-collections-management install user "${WORKSPACE}/item-source"
but the explanation is not sufficient for me, I am not an expert.
I downloaded Tersoff_LAMMPS__MD_077075034781_005 and already installed KIM-API in another directory.
I am not sure what should I do considering the below error messages.
> [yxj200002@ganymede _KIM]$ ls
> build install.txt kim-api-2.3.0 kim-api-2.3.0.txz Tersoff_LAMMPS__MD_077075034781_005 Tersoff_LAMMPS__MD_077075034781_005.txz
[yxj200002@ganymede _KIM]$ kim-api-collections-management install system "/home/yxj200002/_KIM/Tersoff_LAMMPS__MD_077075034781_005/"
CMake Error at CMakeLists.txt:29 (find_package):
Could not find a package configuration file provided by "KIM-API-ITEMS"
(requested version 2.2) with any of the following names:
KIM-API-ITEMSConfig.cmake
kim-api-items-config.cmake
Add the installation prefix of "KIM-API-ITEMS" to CMAKE_PREFIX_PATH or set
"KIM-API-ITEMS_DIR" to a directory containing one of the above files. If
"KIM-API-ITEMS" provides a separate development package or SDK, be sure it
has been installed.
-- Configuring incomplete, errors occurred!
Aborting!
Thank you
