Hello everyone, I get a problem when I tried to use an if structure. My code is below:
label forloopp
variable a loop 50
variable force equal 1.66e-3*v_a
fix increase first addforce v_force 0 0
variable y atom fx[1]
run 1000
if “${y}>5e-12” then “jump SELF forloopp”
next a
jump in.liangbaibu forloopp
It is an overdamped process.My purpose is to make the force in x direction of the first atom as an index. When this force is larger than 5e-12, then I run this system 1000 steps. However, I always get the error message: Substitution for illegal variable in if structure.
I have checked this topic: Illegal Variable Substitution - LAMMPS / LAMMPS Mailing List Mirror - Materials Science Community Discourse (matsci.org). It seemd that it can not address my problem. Thanks for reading and any help will be great.
You must not use an atom style variable in an “if” construct. The condition must be some global expression.
Similarly, you must not use an atom style variable in a ${...}
style variable expansion.
Thanks for your reply!
