Hello all,
I will be appreciated if someone tells me a way to calculate a summation
like the following in a shorter way (the number of variables could be
higher like 81, 125, ...).
variable Jx equal v_Jx1+v_Jx2+v_Jx3+v_Jx4+v_Jx5+v_Jx6+v_Jx7&
+v_Jx8+v_Jx9+v_Jx10+v_Jx11+v_Jx12+v_Jx13+v_Jx14&
+v_Jx15+v_Jx16+v_Jx17+v_Jx18+v_Jx19+v_Jx20+v_Jx21&
+v_Jx22+v_Jx23+v_Jx24+v_Jx25+v_Jx26+v_Jx27
I used a loop-next-jump command but I got this error:
ERROR: Variable has circular dependency (../variable.cpp:1823)
variable sum equal 0
variable i loop 27
label start_of_loop_5
Hello all,
variable i loop 27
variable sum equal v_sum+v_Jx$i
next i
jump SELF start_of_loop_5
you can escape the circular dependency by using an immediate expansion in
between to carry the sum value to the next loop. check this out:
cat in.loopme
variable i1 equal 1
variable i2 equal 10
variable i3 equal 100
variable i4 equal 1000
variable sum equal 0.0
variable i loop 4
label loop
variable hold equal ${sum}
variable sum equal v_hold+v_i$i
print "i=i sum={sum}"
next i
jump SELF loop
print "final sum=${sum}"
axel
p.s.: please note, that any input in LAMMPS that requires *that* many
variables is probably doing something that is much simpler and more
efficiently (and more likely correctly) done in post-processing. script
languages like python are much more suitable for such tasks. please also
note, that recent LAMMPS versions, if compiled accordingly, also support
python style variables to embed python scriptlets.
